Randy, and with all due respect, when you can show me how to get from the model to the detail drg as shown easily I'll be all ears.
Creating views straight from a 3d model may well work for some disciplines and it makes a lot of sense but for detailing you need to pull things apart somewhat to make things easier to make. Even Inventor does the same thing only it does have a 'live' link from the model to the details which is very good.
First off there are much better tools for detailing, but if you're still sticking with autocad, viewports and layer control can do that quite nicely, we did it for years
I call bull.
Call it anything you like, it won't alter the fact that we produced piping design drawings, piping fabrication iso's, structural design drawings and steel fabrication drawings from 3d AutoCAD models for years quite effectively I think there may be samples somewhere on these boards.
Autocad sucks at presenting the model in a layout to make connections and pieces show right. They can't even handle line-display hierarchy decent enough to know not to show beams that are under other beams.
Just cuz' you haven't figured out how to do it yet, doesn't mean it can't be done. Hiding 3D models in viewports is really very simple, dunno about LINEs though, haven't drawn a LINE in nearly ten years.
I've gotten the reply from Autodesk techs saying "Oh yea, I see what problem you're having. Sorry, I get it too, and there's no solution. Maybe next release..."
Well there's your problem, which "Autodesk tech" did you ask about detailing steel??
Example for illustration purposes: I have one angle crossing atop a W-beam, in a top view, for example, it'll show the w-beam top flanges OVER the bottom leg of the angle.
Did you try HIDE?? Haven't had the problem since R13. R14 and R2000 had some issues with cylinders not plotting correctly sometimes, but that's been a while.
For detailing things like this, I -often- resort to showing "flattened" or "solprof'd" views because it works. I often have to create -disassociated- 2d geometry from my nice, neat, accurate 3d-model, to get the job done.
Waste of time, and only works for SOLIDs, won't work on blocks (or anything else), meaning you have to waste even more time during the initial build.
Because in the end, that's what it's about... getting the job done, not maintaining some Holy Order of the CAD File.
Its not about any order of the cad file, its about productivity, or in the case of the scenario above the lack of productivity. With the "stepped on " "stupid graphics", you've divorced the drawings from the model destroying any intelligence in the model, doubling the work required to maintain the files and quadrupling the chance of screwing something up, and then revisions have to be nearly completely re-built from scratch. Sorry that's just not productive, at least it isn't for us.
I love it when people tell us its impossible to do the stuff we've been doing for nearly a decade.
