Author Topic: Table problem  (Read 1298 times)
Xplod
Table problem
« on: February 23, 2009, 10:24:30 AM »
Hello, i'm trying to figure this out.
I want to fill a table with attribute extraction. I'm doing the whole thing, select the table from a pre-made, and it insert the table with all informations. The problem is that, at the end of this table, i'm having a line of text that should be there. Every time the attribute extraction goes, this last line is never there. I'll show it on a pdf (didn't have time to translate it but just look at the last line where it say NOTE)
Can someone give a hint on that ?
Thank you
