Author Topic: Resetting system variables  (Read 2925 times)
It's Alive!
  • Retired
  • AKA Daniel
« on: February 22, 2009, 12:40:53 AM »
Just having a little fun
namespace ExecMethod
  using System;
  using AcAp = Autodesk.AutoCAD.ApplicationServices;
  using SysVar = System.Collections.Generic.KeyValuePair<string, object>;
  public class SysVars
    // Fields
    private Stack<SysVar> _varStack;
    public SysVars()
      this._varStack = new Stack<SysVar>();
    // Properties
    public Stack<SysVar> VarStack
      get { return this._varStack; }
    // Methods
    public void SetVar(string name, object value)
      if (value == null)
        throw new ArgumentNullException("Value");
      object o = AcAp.Application.GetSystemVariable(name);
      AcAp.Application.SetSystemVariable(name, value);
      this._varStack.Push(new SysVar(name, o));
    public SysVar Pop(bool set)
      SysVar var = this._varStack.Pop();
      if (set)
        AcAp.Application.SetSystemVariable(var.Key, var.Value);
      return var;
    public void PopAll(bool set)
      if (set)
        foreach (SysVar var in this._varStack)
      this._varStack.Clear();
and then
    [CommandMethod("doit")]
    public static void doit()
      SysVars vars = new SysVars();
      try
        vars.SetVar("CLAYER", "0");
        //do stuff
      catch
         //catch stuff
      finally
        vars.PopAll(true); //reset the vars
ahlzl
Re: Resetting system variables
« Reply #1 on: February 22, 2009, 04:54:33 AM »
my English is very poor!
Daniel is my idol!Thank you help me on many occasions.You are now in Shanghai, it?
TonyT
« Reply #2 on: February 22, 2009, 05:28:02 AM »
Hi Dan. Cool.
I've yet to come across a situation where I needed a stack-based
approach for that.
I've been using various iterations of this for years:
using System;
using System.Text;
using System.Collections;
using Acad = Autodesk.AutoCAD.ApplicationServices.Application;
namespace CaddZone.AutoCAD.ApplicationServices
   /// example:
   public class Example
      public static void someCommandMethod()
         using( SysVarCache sysvars = new SysVarCache() )
            sysvars["CMDECHO"] = 0;
            sysvars["BLIPMODE"] = 0;
            sysvars["OSMODE"] = 0;
            // Do stuff here
         } // previous values of changed sysvars are restored here
   public sealed class SysVarCache : IEnumerable<KeyValuePair<string, object>>, IDisposable
      private Dictionary<string, object> items = new Dictionary<string, object>( StringComparer.InvariantCultureIgnoreCase );
      private bool changing = false;
      public SysVarCache()
         Acad.SystemVariableChanged += OnSystemVariableChanged;
      // Monitor changes made to system variables by user, so that
      // if they change one that's been saved, (e.g., toggles an
      // item on the status bar or what have you), the saved value
      // gets discarded, preserving the user's new setting.
      void OnSystemVariableChanged( object sender, SystemVariableChangedEventArgs e )
         if( !changing && e.Changed && items.ContainsKey( e.Name ) )
            items.Remove( e.Name );
      public void Restore()
         Restore( true );
      public void Restore( bool clear )
         Acad.SystemVariableChanged -= OnSystemVariableChanged;
         try
            foreach( KeyValuePair<string, object> entry in items )
               object oval = Acad.GetSystemVariable( entry.Key );
               if( !object.Equals( oval, entry.Value ) )
                  Acad.SetSystemVariable( entry.Key, entry.Value );
         finally
         if( clear )
            items.Clear();
      public bool Restore( string name )
         object saved = null;
         if( items.TryGetValue( name, out saved ) && saved != null )
            object oval = Acad.GetSystemVariable( name );
            if( !object.Equals( oval, saved ) )
               this.changing = true;
               try
                  Acad.SetSystemVariable( name, saved );
               finally
                  this.changing = false;
         return items.Remove( name );
      public void Clear()
         items.Clear();
      public int Count
         get
            return items.Count;
      private void Set( string name, object newval )
         if( newval == null )
            throw new ArgumentNullException( "newval" );
         if( string.IsNullOrEmpty( name ) )
            throw new ArgumentNullException( "name" );
         object oldval = Acad.GetSystemVariable( name );
         if( !object.Equals( oldval, newval ) )
            try
               Acad.SetSystemVariable( name, newval );
               if( !items.ContainsKey( name ) )
                  items.Add( name, oldval );
            finally
      // e.g., SetAll( 0, "CMDECHO", "BLIPMODE", "OSMODE" );
      public void SetAll( object value, params string[] names )
         if( names == null )
            throw new ArgumentNullException( "names" );
         try
            foreach( string name in names )
               Set( name, value );
         finally
      // Saves current value without changing it.
      public void Save( params string[] names )
         if( names != null )
                  items.Add( name, Acad.GetSystemVariable( name ) );
      public object this[string name]
         get
            if( items.ContainsKey( name ) )
               return items[name];
            else
               return Acad.GetSystemVariable( name );
         set
            Set( name, value );
      public void Dispose()
         Dispose( true );
      private void Dispose( bool disposing )
         if( disposing )
            Restore();
            GC.SuppressFinalize( this );
         disposed = true;
      private bool disposed = false;
      ~SysVarCache()
         if( !disposed )
            Dispose( false );
      public IEnumerator<KeyValuePair<string, object>> GetEnumerator()
         return items.GetEnumerator();
      public bool Contains( string key )
         return items.ContainsKey( key );
      public ICollection<string> Keys
         get
            return items.Keys;
      // Removes saved value without restoring
      public bool Remove( string key )
         return items.Remove( key );
      public ICollection<object> Values
         get
            return items.Values;
      System.Collections.IEnumerator System.Collections.IEnumerable.GetEnumerator()
It's Alive!
  • Retired
  • AKA Daniel
« Reply #3 on: February 22, 2009, 09:03:51 AM »
Not yet, my flight is Thursday morning, Detroit ->Tokyo->Shanghai, 14 hours flying time  :-o
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: February 22, 2009, 09:05:45 AM »
Hi Dan. Cool.
approach for that.
Wow Tony, that’s really nice, especially the reactor.   8-)
The idea of using a stack came from looking at SdSysVarStack in ArxDbg.
Thanks for sharing!
