Hi all..
I have found an old version of my remake Revcloud..
and modify some options..
There is my version of Cloud..
Ncloud v.1.0 (New Cloud)
this is diffrent of
Dcloud and use simple Pline against blocks.
allow you to draw a cloud and see it dynamicly what is look like before draw.
also,..with Ncloud you can use TAB to reverse each buldge independent or Shift+TAB to reverse all buldge dynamicly during creation.
Ncloud allow you to have open or closed cloud if your pointer are close of the start point it will close automaticly.
you can see these 2 gif below for example.
I have thought to add new feature to change buldge size dynamicly when pressing + or -
...maybe on next release.
for the moment..i just want to share.
![wink ;-)](http://www.theswamp.org/Smileys/black/wink.gif)
Also, I would like to know if some of you use hatch inside closed Cloud revision. !?
just curious to know..
Tanks.
