Author Topic: ArxDbg classes  (Read 1893 times)
It's Alive!
  • BricsCAD
  • AKA Daniel
ArxDbg classes
« on: February 23, 2009, 12:20:34 PM »
Anyone use any of the classes in the ArxDbg? Some of them are pretty slick, like ArxDbgRbList, ArxDbgSelSet and the prompt classes.
I have pulled the classes I like and have made a library, sure does make things simpler
static void ArxLib_doit(void)
    //ArxDbg class to prompt for a double
    ArxDbgUiPrDouble dbl(_T("Enter a tolerance"),NULL, ArxDbgUiPrDouble::kAny);
    if(dbl.go() != ArxDbgUiPrBase::kOk)
      return;
    double val = dbl.value();
    //ArxDbgRbList frees the resbuf
    ArxDbgRbList filter(acutBuildList(RTDXF0,ACRX_T("LINE"),RTNONE));
    CString addPrompt = ACRX_T("\nSelect Lines: ");
    CString remPrompt = ACRX_T("\nRemove Lines: ");
    //ArxDbgSelSet frees the set
    ArxDbgSelSet set;
    if(set.userSelect(addPrompt,remPrompt,filter) != ArxDbgSelSet::kSelected)
      return;
    AcDbObjectIdArray ids
    set.asArray(ids);
    for(int i = 0; i < ids.length(); i++)
      AcDbLinePointer ptr(ids[i],AcDb::kForRead);
      if(ptr.openStatus() != Acad::eOk)
        continue;
      if(ptr->startPoint().distanceTo(ptr->endPoint()) < val)
        ptr->upgradeOpen();
        acutPrintf(_T("\nErased %ld"),(long)(AcDbStub*)ptr->objectId());
        ptr->erase();
