Author Topic: OFFSET closed polyline  (Read 5301 times)
Andrea
« on: October 12, 2004, 03:02:07 PM »
I need to make an offset of a close polyline INSIDE at 2 unit by selecting
1 time the polyline.
So I have no idea how to get the inside of Polyline..see ?
any help here..
thanks.
Keep smile...
Jassper
« Reply #1 on: October 12, 2004, 04:04:06 PM »
Can you be a little more specific -
if it will not offset to the inside then the "offset Distance" is too Large
or am I missing something?
Little
Command: _pline
Specify start point:
Current line-width is 0.0000
Specify next point or [Arc/Halfwidth/Length/Undo/Width]:
Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]:
Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]: c
Command:
OFFSET
Specify offset distance or [Through] <2.0000>:
Select object to offset or <exit>:
Specify point on side to offset:
Command:
OFFSET
Cannot offset that object.
« Reply #2 on: October 12, 2004, 04:07:59 PM »
(defun c:OffsetInside ( / dist ename vobj )
  (setq dist 2)
  (setq ename (car (entsel "\nSelect object to offset: ")))
  (setq vobj (vlax-ename->vla-object ename))
  (if (vlax-method-applicable-p vobj 'Offset)
      ;;(vlax-invoke vobj 'Offset dist) ; outside
      (vlax-invoke vobj 'Offset (- dist))
    (princ "\nCannot offset selected object type ")
) ;end
Andrea
« Reply #3 on: October 13, 2004, 09:02:20 AM »
Hi CAB and thanks for the help.
I have noted a little mistake (in RED).
  (setq dist 2)
     (vlax-invoke vobj 'Offset dist) ; INSIDE
     ;; (vlax-invoke vobj 'Offset (- dist))
) ;end
you can also change the (setq dist 2) by (setq dist -2)
thanks again.   :wink:
Keep smile...
« Reply #4 on: October 13, 2004, 10:58:47 AM »
Quote from: Andrea
Quote from: Help File
The distance to offset the object. The offset can be a positive or negative number, but it cannot equal zero. If the offset is negative, this is interpreted as being an offset to make a "smaller" curve (that is, for an arc it would offset to a radius that is "Distance less" than the starting curve's radius). If "smaller" has no meaning, then it would offset in the direction of smaller X, Y, and Z WCS coordinates.
Andrea negative numbers offset to the inside not positive numbers.
Your correction is incorrect. :wink:
Andrea
« Reply #5 on: October 13, 2004, 11:18:36 AM »
Quote from: CAB
CAB,
sorry, but it was tested.
don't tell me why ..??
but it work. :D
Keep smile...
Andrea
« Reply #6 on: October 13, 2004, 11:45:37 AM »
hey !!  I have made more tests...
the result is...
sometime is offset outside....and sometime offset inside..
????? very strange..
Keep smile...
« Reply #7 on: October 13, 2004, 12:34:40 PM »
Hummmm, at 2 units, do you think you were zoomed out too far?
Just a guess 8)
Andrea
« Reply #8 on: October 13, 2004, 12:48:44 PM »
I've tried both....!!
 :cry:
Keep smile...
Serge J. Gianolla
« Reply #9 on: October 13, 2004, 08:19:52 PM »
This is due to direction of your pline. +ve value on CCW will be resulting on same as -ve value on CW, and vice-versa.
« Reply #10 on: October 13, 2004, 11:16:31 PM »
Serge,
Never knew that..Guess it never bit me.
So, you need to determine the direction of the polyline before applying the offset.
Andrea do you have the code to do that?
« Reply #11 on: October 14, 2004, 12:19:12 AM »
Here is one way:
(defun c:ofs (/ dist ename vobj)
  (setq dist 5)
  (if (vlax-method-applicable-p vobj 'offset)
      (if (member (cdr (assoc 0 (entget ename)))
                  '("AECC_CONTOUR" "LWPOLYLINE" "POLYLINE") )
        (if (= "CCW" (@polydir ename))
          (vlax-invoke vobj 'offset dist)
          (vlax-invoke vobj 'offset (- dist))
) ;end
;; PolyDir.LSP v1.0 (03-05-02) John F. Uhden, Cadlantic
;; This is freeware dedicated to Noah (?) and Cliff Middleton
;; This function returns the deflection angle (in radians) of two angles:
(defun @delta (a1 a2)
    ((> a1 (+ a2 pi)) (setq a2 (+ a2 (* 2 pi))))
    ((> a2 (+ a1 pi)) (setq a1 (+ a1 (* 2 pi))))
  (- a2 a1)
;; Function returns a list of 3D points from a continuous list
;; as returned by (vlax-safearray->list (vlax-variant-value X))
(defun @cv_parse_list (data n / item new)
  (foreach element (reverse data)
    (setq item (cons element item))
    (if (= (length item) n)
      (setq new  (cons item new)
            item nil
  new
(defun @polydir (e / ent etype object coords flag i p1 p2 p3 sum)
    ((/= (type e) 'ename) nil)
    ((not (vl-position (setq etype (cdr (assoc 0 (setq ent (entget e)))))
                       '("AECC_CONTOUR" "LWPOLYLINE" "POLYLINE")))
     (prompt (strcat " Object selected is a(n) " etype))
    ((and (setq flag (cdr (assoc 70 ent))) (> (boole 1 16 flag) 0))
     (prompt " Object selected is a 3DMESH")
    (1
     (setq object (vlax-ename->vla-object e)
           coords (vlax-get object "Coordinates")
           coords (@cv_parse_list coords
                                  (if (= etype "LWPOLYLINE") 2 3))
           i      1
           sum    0.0
     (and flag
          (= (logand 1 flag) 1) ; closed
          (setq coords (reverse (cons (car coords) (reverse coords))))
     (repeat (- (length coords) 2)
       (setq p1  (nth (1- i) coords)
             p2  (nth i coords)
             i   (1+ i)
             p3  (nth i coords)
             sum (+ sum (@delta (angle p1 p2) (angle p2 p3)))
     (if (minusp sum) "CW" "CCW")
daron
« Reply #12 on: October 14, 2004, 08:53:24 AM »
My first reading of this thread implied programming, therefore... *poof*.
