Author Topic: repathing  (Read 8998 times)
Re: repathing
« Reply #15 on: January 27, 2009, 04:22:09 PM »
You're welcome Deegs.  Could you post one of the drawings?  No need for the images, I just want to see if I can get them to repath with the code, as it was working here.
You can do this type of thing with ObjectDBX, so you could run through a folder pretty quickly.  Could be done in any language your comfortable with also.
I'm glad you got something, but you shouldn't have to resort to ' command ' calls.   :wink:
deegeecees
Re: repathing
« Reply #16 on: January 27, 2009, 04:31:32 PM »
I would, but there's way too much proprietary info on them. I was getting an error saying that the file couldn't be accessed, could be that it wasn't released from the first run through...
Yes, I have some ODBX code for VBA, but it's been quite a few years since I've dived into coding, and I needed something quick. <---------Boilerplate Disclaimer
Hehe, I'm just a hack.
Re: repathing
« Reply #17 on: January 27, 2009, 04:41:55 PM »
Cool.  I understand.  Next time try this little diddy.  I made the variables local, and have it print the old path and the new path per image file, so that you can see if it does change it or not.
(defun c:im_upd2 (/ new_path img_file_name)
    (setq new_path (GETVAR "DWGPREFIX"))
    (vlax-for i (vla-get-Layouts (vla-get-ActiveDocument (vlax-get-Acad-Object)))
        (if (= (vla-get-Name i) "00")
            (vlax-for item (vla-get-Block i)
                    (and
                        (= (vla-get-objectname item) "AcDbRasterImage")
                        (vlax-property-available-p item 'ImageFile)
                        (setq img_file_name
                            (strcat
                                (vl-filename-base (vla-get-ImageFile item))
                                (vl-filename-extension (vla-get-ImageFile item))
                        (print (vla-get-ImageFile item))
                        (vla-put-imagefile
                            item
                            (strcat new_path img_file_name)
);;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;defun---End Prog
deegeecees
Re: repathing
« Reply #18 on: January 27, 2009, 04:44:45 PM »
error: Automation Error. File access error
I'm using 04 btw...
Re: repathing
« Reply #19 on: January 27, 2009, 04:46:40 PM »
I'm using 04 btw...
Post the whole error message with this one.
(defun c:im_upd2 (/ new_path img_file_name *error*)
    (defun *error* (msg) (vl-bt))
                    (and
                        (setq img_file_name
                            (strcat
                        (vla-put-imagefile
                            item
Don't think that should be an issue with this.
deegeecees
Re: repathing
« Reply #20 on: January 27, 2009, 04:59:32 PM »
It was erroring from an image file that has a different path altogether, once I detached it all is well. I'll have to add an exclusion for that image, as it's a part of our title blocks, and add something for missing files as well for this to work in variable situations.
Re: repathing
« Reply #21 on: January 27, 2009, 05:10:55 PM »
It may not work if there is no file at the new path, so you can just check to see if the new path exist, ' findfile ', and if so, then repath it.  If not, print it to the command line that the new path was not found... yada yada yada.
deegeecees
Re: repathing
« Reply #22 on: January 27, 2009, 05:13:11 PM »
Yes sir, I'll post the code when I get it to work "Correctly".
VVA
Re: repathing
« Reply #23 on: January 28, 2009, 02:26:02 AM »
