Author Topic: repathing  (Read 9003 times)
daron
repathing
« on: October 12, 2004, 01:16:11 PM »
Recently, my employ went and upgraded their servers. Yeah for them. They decided that it would not be too much of a headache to go ahead and change the name of the root directory in the server. Here is the problem. My group (division) attaches images everywhere. We also have a few xrefs. I've been trying to remove the old path name from a given point and replace it with the new path name to that given point. I have all the details worked out, but for some reason vla-put-ImageFile won't work.
     (vl-catch-all-apply
     '(foreach item objects
 (if (vlax-property-available-p item 'ImageFile)
      (setq filename (vla-get-imagefile item)
    path     (newpath filename)
      (vlax-put-property item 'ImageFile path)
The catch all helps for trapping, but it seems to stop the iteration on the first error.  Without the catch all, I get a file access error. Can someone help?
repathing
« Reply #1 on: October 12, 2004, 01:54:56 PM »
How about something like this;
(setq mspace
  (vla-get-modelspace
(vla-get-activedocument (vlax-get-acad-object)
(setq new_path "c:\\Temp\\src\\")
(vlax-for item mspace
  (if (= (vla-get-objectname item) "AcDbRasterImage")
(setq img_file_name
  (strcat
(vl-filename-base (vla-get-ImageFile item))
(vl-filename-extension (vla-get-ImageFile item))
(vla-put-imagefile
 item
 (strcat new_path img_file_name)
repathing
« Reply #2 on: October 12, 2004, 02:51:02 PM »
Daron
I can't make your vl-catch-all-apply work at all.
repathing
« Reply #3 on: October 12, 2004, 02:59:51 PM »
Quote from: Mark Thomas
Daron
never mind ............  :roll:
daron
repathing
« Reply #4 on: October 12, 2004, 03:12:49 PM »
I think the problem is that I'm currently accessing the links, even though they are broken. Would it work better in vba and if not, would it be possible with objectdbx and does anybody know how to formulate something like this in dbx?
For those interested in dbx, here's something I got from vbdesign on the subject. It most likely won't work right out, but should give a start in it. I for one don't yet understand it.
Option Explicit
Const ATTR_DIRECTORY = 16
Dim objAcad As AcadApplication
Public Sub main()
  Dim FileArray As Variant
  Dim strDir As String
  Dim i As Integer
  'acad must be running
  Set objAcad = GetObject(, "AutoCAD.Application")
  strDir = "P:\Temp\test" 'your dir goes here
  FileArray = GetFilesInDir(strDir)
  For i = 0 To UBound(FileArray)
    OpenAndDoStuff strDir & FileArray(i)
  Next i
  MsgBox i & " Files Processed"
End Sub
Public Function GetFilesInDir(pDir As String) As Variant
  Dim dirReturn As String
  Dim subFiles As String
  Dim intLen As Integer
  Dim intCount As Integer
  Dim varRet() As Variant
  intLen = Len(pDir)
  If Mid(pDir, intLen, 1) <> "\" Then
    pDir = pDir & "\"
  End If
  dirReturn = Dir(pDir & "*.dwg")
  'First we find all of the subdirs
    Do While dirReturn <> ""
      DoEvents
      If GetAttr(pDir & dirReturn) <> ATTR_DIRECTORY Then
        ' that is NOT a dir so add it to listbox
        subFiles = dirReturn
        ReDim Preserve varRet(0 To intCount)
        varRet(intCount) = subFiles
        intCount = intCount + 1
      End If
    dirReturn = Dir
  Loop
  GetFilesInDir = varRet
End Function
Private Function OpenAndDoStuff(strFileName As String) As Variant
  Dim objDbx As Object
  Dim i As Integer
  Dim objAcadEnt As AcadEntity
  Dim objBlockRef As AcadBlockReference
  Dim objLayer As AcadLayer
  Dim strSearchBlckName As String
  Dim dblSearchScale As Double
  Dim dblCurrScale As Double
  Dim dblNewScale As Double
  Dim basePt(0 To 2) As Double
  On Error GoTo Err_Control
  'set up search parameters. these should be passed in as args
  dblSearchScale = 48#
  strSearchBlckName = "borsiv36"
  Set objDbx = objAcad.GetInterfaceObject("ObjectDBX.AxDbDocument")
  objDbx.Open strFileName
  i = 0
  For Each objAcadEnt In objDbx.ModelSpace
      If TypeName(objAcadEnt) = "IAcadBlockReference" Then
        Set objBlockRef = objAcadEnt
        If objBlockRef.Name = "borsiv36" Then
            dblCurrScale = objBlockRef.XScaleFactor
            Exit For ' assumes only one block of borsiv36 in file
          End If
      End If
  Next objAcadEnt
  If dblCurrScale <> dblSearchScale Then
    dblNewScale = dblSearchScale / dblCurrScale 'set up the scale-by factor
    'just in case layers are locked, unlock them
    For Each objLayer In objDbx.Layers
      objLayer.Lock = False
    Next objLayer
    'scale all the modelspace entities by the new factor
      objAcadEnt.ScaleEntity basePt, dblNewScale
    Next objAcadEnt
    objDbx.SaveAs strFileName
  Else
  End If
  Debug.Print "Finished " & strFileName
  Set objDbx = Nothing
Exit_Here:
  Exit Function
Err_Control:
  MsgBox Err.Description
  Resume Exit_Here
End Function
Option Explicit
Public FileInfo() As String
Public Type BROWSEINFO
  hOwner As Long
  pidlRoot As Long
  pszDisplayName As String
  lpszTitle As String
  ulFlags As Long
  lpfn As Long
  lParam As Long
  iImage As Long
End Type
Public Const MAX_PATH = 2600
Declare Function SHBrowseForFolder Lib "shell32.dll" _
Alias "SHBrowseForFolderA" (lpBrowseInfo As BROWSEINFO) As Long
Declare Function FindWindow Lib "user32" _
Alias "FindWindowA" (ByVal lpClassName As String, _
ByVal lpWindowName As String) As Long
Declare Function SHGetPathFromIDList Lib "shell32.dll" _
Alias "SHGetPathFromIDListA" (ByVal pidl As Long, _
ByVal pszPath As String) As Long
Public Sub BatchDBX()
  Dim frmDBX As New UserForm1
  frmDBX.Show
  Set frmDBX = Nothing
End Sub
Public Function ReturnFolder(lngHwnd As Long) As String
Dim Browser As BROWSEINFO
Dim lngFolder As Long
Dim strPath As String
With Browser
.hOwner = lngHwnd
.lpszTitle = "Select Directory to work in"
.pszDisplayName = String(MAX_PATH, 0)
End With
strPath = String(MAX_PATH, 0) '<-- VERY Important!!
lngFolder = SHBrowseForFolder(Browser)
If lngFolder Then
  SHGetPathFromIDList lngFolder, strPath
  ReturnFolder = Left(strPath, InStr(strPath, vbNullChar) - 1)
End If
End Function
Public Function ParseOut(strIn As String, strChar As String) As String
   Dim intCnt As Integer
   Dim strFile As String
   intCnt = 1
   Do
    If Mid(strIn, intCnt, 1) = strChar Then
      strFile = Mid(strIn, 1, intCnt - 1)
      strIn = Mid(strIn, intCnt + 1, Len(strIn))
      ParseOut = strFile
      Exit Function
    End If
    intCnt = intCnt + 1
   Loop
End Function
daron
repathing
« Reply #5 on: October 12, 2004, 04:38:15 PM »
This seems to work for the time being. I still have to make it accept xrefs. We'll see how it goes tomorrow. I'm out for the day. Here's a new snippet.
      (vl-catch-all-apply
   '(mapcar
     '(lambda (x)
   (if (vlax-property-available-p x 'ImageFile)
     (setq filename (vla-get-imagefile x)
     (vlax-put-property
  x
  'ImageFile
  path
     objects
   objects
deegeecees
Re: repathing
« Reply #6 on: January 27, 2009, 12:04:06 PM »
How would one get this to work for images in a Layout Tab named "00" (no quotations)?
(setq mspace
   (vla-get-modelspace
(setq img_file_name
   (strcat
(vla-put-imagefile
  item
Re: repathing
« Reply #7 on: January 27, 2009, 12:22:40 PM »
Just cycle through the layout collection.  When you find the one you want, assign the variable ' mspace ' to the layout object.
(vlax-for i (vla-get-Layouts (vla-get-ActiveDocument (vlax-get-Acad-Object)))
    (if (= (vla-get-Name i) "LayoutNameHere")
        (vlax-for j (vla-get-Block i) [color=red];  <-- This line equals ' (vlax-for item mspace ' in the code below.[/color]
            .... do the magic here ...
Edit:  You can check here also.
[ http://www.theswamp.org/index.php?topic=26834.0 ]
(setq mspace
   (vla-get-modelspace
(setq img_file_name
   (strcat
(vla-put-imagefile
  item
deegeecees
Re: repathing
« Reply #8 on: January 27, 2009, 01:21:58 PM »
    (if (= (vla-get-Name i) "00")
This returns NIL when I run it on a drawing with images in a layout named "00". Shouldn't it return the name of the layout?
Re: repathing
« Reply #9 on: January 27, 2009, 01:29:13 PM »
That should error, since it doesn't know how to interpret the ' ... ', but if you placed the code, then a nil is okay, as that is what is returned by a lot of ActiveX stuff in Lisp.
deegeecees
Re: repathing
« Reply #10 on: January 27, 2009, 01:45:08 PM »
Sorry, but it's been a while since I've coded, not sure where to separate things here. This is what I've got, and am getting a "error: bad argument type: stringp nil" message when I run it.
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;start prog
(defun c:im_upd2 ()
(setq new_path (GETVAR "DWGPREFIX"))
        (vlax-for item (vla-get-Block i)
(setq img_file_name
    (strcat
(vla-put-imagefile
  item
);;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;defun---End Prog
Sorry for being such a pain...
Re: repathing
« Reply #11 on: January 27, 2009, 01:52:28 PM »
It worked for me.  The only thing I can think of is if the file name is not set, so you are getting a nil for that.  Code just re-formated.
(defun c:im_upd2 ()
                        (setq img_file_name
                            (strcat
                        (vla-put-imagefile
                            item
deegeecees
Re: repathing
« Reply #12 on: January 27, 2009, 02:23:15 PM »
Drawing is named, and 4 raster files reside in a layout named "00".
Here's my situation, we have quite a few drawings with images pathed to c:\documents and settings\administrator\... (yeah, I know), and I want to strip out the "documents and settings\administrator" part of it. I've never dealt with images or ActiveX stuff before, so I'm just looking for a quick solution on this. Got anything that would do that?
deegeecees
Re: repathing
« Reply #13 on: January 27, 2009, 02:33:15 PM »
Bahhh...
I'll just use the Ref Manager for now...
deegeecees
Re: repathing
« Reply #14 on: January 27, 2009, 04:09:01 PM »
I just couldn't leave it til I got something to work. This is cludgy, but effective:
(defun c:im_upd2 ()
                        (setq img_file_name01
                            (strcat
                        (setq img_file_name02
                            (strcat
                        (setq im_full (strcat new_path img_file_name01))
;(print im_full)
(command "-image" "p" img_file_name02 im_full)
Thank you very much for the help T-Dubya.
