Author Topic: How can I know if the shapes are the same?  (Read 9053 times)
litss
« on: February 16, 2009, 09:08:13 AM »
I wish I could find a way to group shapes(closed pline) that are the same. But it is hard for me. Any one have a good idea? Thx!
Attached is a fig. If I select all the shapes by "ssget", I want a way to find out the "1" and "2", which are the same shapes.
Re: How can I know if the shapes are the same?
« Reply #1 on: February 16, 2009, 10:13:57 AM »
There are lots of common items that can be compared but absolute conformation may be complex.
This is what I would check.
Both are LWPolylines
Both are closed or open
They have the same length & area
They have the same number of segments
May not need this one but check that the segment lengths are the same
That should be a good test.
« Reply #2 on: February 16, 2009, 10:29:34 AM »
That's scary...this is what I was starting to write. :-D
« Reply #3 on: February 16, 2009, 10:59:42 AM »
You are just being LOGICAL.  :lmao:
litss
« Reply #4 on: February 16, 2009, 11:15:59 AM »
It's for sure: Both are LWPolylines & Both are closed
And I can do comparison of length & area. But it's not enough. There are hundreds of plines in my draft, length & area are all close to each other.
:( the problem is how to check each segment length? starting from which leg of the plines?  it might be a huge comparison. quite hard for me...
« Reply #5 on: February 16, 2009, 11:51:22 AM »
Look into these functions. They will get you what you need.
(vlax-curve-getarea curve-obj)
(vlax-curve-getclosestpointto curve-obj givenPnt [extend])
(vlax-curve-getclosestpointtoprojection curve-obj givenPnt normal [extend])
(vlax-curve-getdistatparam curve-obj param)
(vlax-curve-getdistatpoint curve-obj point)
(vlax-curve-getendparam curve-obj)
(vlax-curve-getendpoint curve-obj)
(vlax-curve-getfirstderiv curve-obj param)
(vlax-curve-getparamatdist curve-obj dist)
(vlax-curve-getparamatpoint curve-obj point)
(vlax-curve-getpointatdist curve-obj dist)
(vlax-curve-getpointatparam curve-obj param)
(vlax-curve-getsecondderiv curve-obj param)
(vlax-curve-getstartparam curve-obj)
(vlax-curve-getstartpoint curve-obj)
(vlax-curve-isClosed ent) ; true if Closed
Spike Wilbury
« Reply #7 on: February 16, 2009, 04:56:39 PM »
That is a very good link. Thanks 8-)
Spike Wilbury
« Reply #8 on: February 16, 2009, 05:09:24 PM »
Yes... Alan,
That's one of my old url kept for quite a while.... :)
ps> using a default name - me
SomeCallMeDave
« Reply #9 on: February 16, 2009, 05:15:05 PM »
I haven't done a rigorous proof (have done no proof at all really), but it would seem to me that the sum of the distances from the centroid to each vertex would be a unique value for each shape and would be independent of the rotation of the shape.
And it would be a quick calculation:
  for each shape:
          calc the centroid
          build a vertex list (just an (assoc 10) list since the OP said all shapes are LwPoly)
          then sum the distances ->     (apply '+ (mapcar '(lambda (x) (distance x centroid)) vertlist))
Build a list containing each value, find the matches, use the index of the list to pull the entities from the selection set.
Almost writes itself  :)
« Reply #10 on: February 16, 2009, 05:33:53 PM »
Give this a try....seems to work OK for me  :-)  **will not work if you reverse the vertexes  fixed.
(defun c:similar_polylines (/ d lst n n2 obj out ss)
  (setq n -1)
  (if (setq ss (ssget '((0 . "LWPOLYLINE"))))
    (progn (repeat (sslength ss)
             (setq obj (vlax-ename->vla-object (ssname ss (setq n (1+ n))))
                   n2  0.0
                   d   nil
             ;;get distances between vertexes  **accuracy is 5 decimal places
             (repeat (fix (vlax-curve-getendparam obj))
               (setq d (cons (rtos (distance (vlax-curve-getpointatparam obj n2)
                                             (vlax-curve-getpointatparam obj (setq n2 (1+ n2)))
                                   2
                                   5
                             d
             ;;put all the information into the list to check
             (setq lst (cons (list obj
                                   (rtos (vla-get-area obj) 2 5)
                                   (vla-get-closed obj)
                                   (rtos (vla-get-length obj) 2 5)
                                   (vl-sort d '>)
                             lst
           ;;iterate the list checking for more than one occurence of the first element properties
           (foreach pl lst
             (if (> (length (vl-remove-if-not '(lambda (x) (equal x (cdr pl)))
                                              (mapcar 'cdr lst)
                    1
               (setq out (cons (car pl) out))
  ;;(foreach x out (vla-put-color x 3))
  ;;quick check
  out
(c:similar_polylines)
« Last Edit: February 16, 2009, 06:17:57 PM by ronjonp »
litss
« Reply #11 on: February 17, 2009, 01:48:38 AM »
Thx all of u guys! helped me a lot..
to:  David Blackmon
I like ur way "the sum of the distances from the centroid". I'll try it tonight :)
to: ronjonp
ur routine runs perfectly. And I made some modification so that it could group each kind of shapes as a list. Hope you don't mind. I am poor at programing, so it might not look as clean as urs :). here's it:
  (setq n -1)
              n2 0.0
              d nil
        )             ;;get distances between vertexes  **accuracy is 5 decimal places
                              ) 2 5
                        ) d
        )             ;;put all the information into the list to check
        (setq lst (cons (list obj (rtos (vla-get-area obj) 2 5) (vla-get-closed obj) (rtos
        2 5
                              (vlax-curve-getendparam obj) (vl-sort d '>)
                        ) lst
      )           ;;iterate the list checking for more than one occurence of the first element properties
   ;;;------------------modified------------------------------------------------
      (setq out '())
      (while (> (length lst) 0)
        (setq pl (car lst))
        (setq lst0 (vl-remove-if-not '(lambda (x)
                                        (equal (cdr x) (cdr pl))
                                      ) lst
        (setq out (cons lst0 out))
        (setq n 0)
        (repeat (length lst0)
          (setq pl (nth n lst0))
          (setq lst (vl-remove-if '(lambda (x)
                                   ) lst
          (setq n (1+ n))
        );repeat
      );while
  (setq n 3)
  (foreach x out
    (setq n (1+ n))
    (foreach y x
      (vla-put-color (car y) n)
  )  ;;quick check
« Reply #12 on: February 17, 2009, 10:18:12 AM »
Glad it worked for you :)
« Reply #13 on: February 17, 2009, 10:41:11 AM »
Here is how I would group the objects as sublists.
(defun c:similar_polylines (/ d lst n n2 obj out ss sub)
  (setq n -1)
                   n2  0.0
                   d   nil
               (setq
                               2
                               5
                         d
                                   (vl-sort d '>)
                             lst
           (foreach pl lst
             (if (> (length
                      (setq sub (vl-remove-if-not '(lambda (x) (equal (cdr x) (cdr pl)))
                                                  lst
                    1
               (progn (setq out (cons (mapcar 'car sub) out))
                      (setq lst (vl-remove-if '(lambda (x) (member x sub)) lst))
  (setq n 0)
  (foreach pl out
    (setq n (1+ n))
    (mapcar '(lambda (x) (vla-put-color x n)) pl)
  out
Here is one using David's centroid\vertex distance method...same results as the one above  :-)
(defun c:similar_polylines (/ e lst m n out pts ss sub sum x)
  (setq n -1)
             (setq e (ssname ss (setq n (1+ n))))
             (setq pts (mapcar 'cdr
                               (vl-remove-if-not '(lambda (x) (= 10 (car x))) (entget e))
                   m   (list (/ (apply '+ (mapcar 'car pts)) (length pts))
                             (/ (apply '+ (mapcar 'cadr pts)) (length pts))
                   ;;same 5 decimal precision
                   sum (apply '+
                              (mapcar 'atof
                                      (mapcar '(lambda (x) (rtos (distance m x) 2 5)) pts)
                   lst (cons (list e sum) lst)
           (foreach pl lst
             (if (> (length
                                                  lst
                    1
  (setq n 0)
  (foreach pl out
    (setq n (1+ n))
    (mapcar '(lambda (x) (vla-put-color (vlax-ename->vla-object x) n))
            pl
  out
« Last Edit: February 17, 2009, 11:44:52 AM by ronjonp »
SomeCallMeDave
« Reply #14 on: February 17, 2009, 01:51:11 PM »
Very nice Ron.
I like your method of calculating the centroid.  Much more concise than mine.
« Reply #15 on: February 17, 2009, 01:56:46 PM »
Very nice Ron.
Thanks David :) I like this solution as well for averaging the point list
(mapcar '(lambda (x) (/ x (length points))) (apply 'mapcar (cons '+ points))) I grabbed it from somewhere off the swamp....perhaps MP's or Giles code?
litss
« Reply #16 on: February 18, 2009, 08:27:05 AM »
wow, ronjonp, u r fast :)
ur way is better. I still have some problems in applying the "mapcar" and "lambda". hard to understand...need to do more homework
My way of calculating the centroid is much more complicated and much slower than urs. Do we get the same centroid by these two methods? Here's mine.
  (defun centroid (ENT /)
    (command "_REGION" ENT "")
    (setq p1 (vlax-safearray->list (vlax-variant-value
                                                       (vla-get-centroid
        (ENTLAST)
    (entdel (entlast))
    p1
« Reply #17 on: February 18, 2009, 09:48:06 AM »
From my tests they return different results depending on the shape (square\rectangle same) other polygons different. My guess is the centroid function uses more points along the boundary.
You can shorten your routine above by using "vlax-get" since it will return the point and not a variant.
(defun centroid (ent /)
  (command "_REGION" ent "")
  (setq p1 (vlax-get (vlax-ename->vla-object (entlast)) 'centroid))
Enjoy :)
