Author Topic: SSGET variable?  (Read 5891 times)
Daniel J. Ellis
SSGET variable?
« on: February 16, 2009, 09:06:14 AM »
I'm working on a routine that selects all the objects on a layer, quite simply just:
<code>(SETQ ss (SSGET "x" '((8 . "0-fdp-h-nos-plot"))))</CODE>
However, I want to the routine to be able to select one of a number of layers, then do the SSGET on the specified layer:
(CODE>(SETQ ss (SSGET ("x" '((8 . layer)))))</CODE>
but test runs don't seem to like this.  Can anybody suggest anything?
Not got time to test now, but I've just wondered if I can go
<CODE>(setq SS (ssget "X" laylist))</code>
Having previously defined laylist as being equivilent to (8 . layer).  Does that sound plausible?
dJE
dJE
litss
Re: SSGET variable?
« Reply #1 on: February 16, 2009, 09:18:17 AM »
you gotta use "and" or "or", something like:
(ssget '((-4 . "<OR") (-4 . "<AND")
                             (0 . "TEXT")
                             (8 . "12")
                             (-4 . "AND>")
                             (-4 . "<AND")
                             (0 . "*LINE")
                             (8 . "0")
                             (-4 . "AND>")
                             (-4 . "OR>")
hope it helps :)
Re: SSGET variable?
« Reply #2 on: February 16, 2009, 09:41:05 AM »
This routine is a good example of how to create a list of layers for ssget
http://www.theswamp.org/index.php?topic=1915.0
You can also combine layer names as a text string separating them with a comma like this:
(setq ss (ssget "_X" '((8 . "layer1,Layer2,Layer3"))))You may also use wildcard characters in the string names.
GDF
Re: SSGET variable?
« Reply #3 on: February 16, 2009, 10:19:59 AM »
Alan
I get the following error with the csel routine:
elect object for color filter.; error: bad argument type: stringp T
Gary
Re: SSGET variable?
« Reply #4 on: February 16, 2009, 10:24:23 AM »
And just to clarify your intial question, this:
(SETQ ss (SSGET ("x" '((8 . layer))))) needs to look like this:
(SETQ ss (SSGET ("x" (list (cons 8  layer)))))When you have a variable in a list, that list must be generated with (cons). Quoted lists may only be used when no variables are involved.
Re: SSGET variable?
« Reply #5 on: February 16, 2009, 10:57:29 AM »
Alan
Gary
I can't recreate the error. Would you mind running the lisp with VLIDE & tell me which line the error occurs?
If here (while (setq ent (entsel col:prompt))
what is in the variable col:prompt ?
GDF
Re: SSGET variable?
« Reply #6 on: February 16, 2009, 11:09:43 AM »
Alan
Gary
Alan
The vlide editor stops here:
(get_color_name col)
Gary
Daniel J. Ellis
Re: SSGET variable?
« Reply #7 on: February 16, 2009, 04:15:41 PM »
That's exactly the answer I was looking for, thanks Jeff :)
dJE
dJE
Re: SSGET variable?
« Reply #8 on: February 16, 2009, 04:45:58 PM »
Gary,
Looks like the code here
      (setq col (cdr (assoc 62
                            (tblsearch "layer"
                                     (cdr (assoc 8 (entget (car ent))))))))
is not returning a color number. It might be a True Color issue, not sure.
No error in ACAD2k, but I'll try to check it out in 2k6.Don't have anything newer.  :-(
GDF
Re: SSGET variable?
« Reply #9 on: February 16, 2009, 06:12:01 PM »
Gary,
                            (tblsearch "layer"
Ok, thanks Alan
Re: SSGET variable?
« Reply #10 on: February 16, 2009, 07:21:52 PM »
Alan, not sure why it works in 2000...... :-)
Your function (get_color_name) returns T or nil, not the color as intended. This makes the (strcat) function fail since there is always a T returned...(strcat "Textstring " T) fails.
Changing that function to this allows it to work correctly.
(defun get_color_name (c# / col)
    (setq col (assoc c# '((1  "Red")
                          (2  "Yellow")
                          (3  "Green")
                          (4  "Cyan")
                          (5  "Blue")
                          (6  "Magenta")
                          (7  "Black/White")
                          (8  "Dark Grey")
                          (9  "Grey"))
    (or (cadr col) (setq col (itoa c#)));;changed this line
    col ;;added this line
HTH
Re: SSGET variable?
« Reply #11 on: February 16, 2009, 11:45:13 PM »
Jeff, I thought you were crazy until I went and looked at the code in the link.
Sure enough I had updated the code in my computer but never updated the posted code.
Thanks for keeping an eye out.
This was my sub and the reason it always worked for me  :oops:
 I did change the code out today. (not sure how that one was never caught.)
  ;; return the color name from the color number supplied
  ;; else return the number as a string
                          (2  "Yellow")
                          (3  "Green")
                          (4  "Cyan")
                          (5  "Blue")
                          (6  "Magenta")
                          (7  "Black/White")
                          (8  "Dark Grey")
                          (9  "Grey"))
    (if col
      (cadr col)
      (itoa c#))
Re: SSGET variable?
« Reply #12 on: February 17, 2009, 01:15:32 AM »
Probably right about that.
No problem. And I see that my "fixed" code fragment only fixed part of it. If the color was one that returns a named value, mine would fail since I neglected to note that you have col as a list.
My turn for an :oops:
GDF
Re: SSGET variable?
« Reply #13 on: February 17, 2009, 10:35:38 AM »
Thanks Alan, it works perfectly now.
Re: SSGET variable?
« Reply #14 on: February 17, 2009, 11:44:13 AM »
You're welcome & thanks for reporting the error. 8-)
