Author Topic: Are there anymore tools to clean a drawing of junk?  (Read 11342 times)
Krushert
  • FREE BEER Tomorrow!!
Re: Are there anymore tools to clean a drawing of junk?
« Reply #15 on: February 11, 2009, 01:37:21 PM »
The other thing  I noticed with the blocks is that I can only see and touch 3 blocks with the name fork_truck but the counts is stating that there are 94.  Am I reading info from the counts correctly?
you routine came back with 7 instances for the for truck block but Quick Select confrim my 3.
A "I don't know" shrug with shoulder pads
Matt__W
  • I like my water diluted.
« Reply #16 on: February 11, 2009, 01:48:42 PM »
Shoulder pads??  Seriously??    :?
Autodesk Expert Elite
« Reply #17 on: February 11, 2009, 02:05:52 PM »
Did you erase any in the current drawing session?  I know that if you erase one, then block record still shows that it is there, but it really isn't in the drawing.  It is stored for undo reasons.  That would be a simple check to do if you need it.
Edit:  It looks like the block Michael was worried about are inserted more than once.  Which could be a reason for the high file size.
("A$C460E5761" . 4)
("A$C33915B18" . 5)
 A$C33915B18.Count = 800
 A$C460E5761.Count = 513
Krushert
« Reply #18 on: February 11, 2009, 02:14:46 PM »
("A$C460E5761" . 4)
("A$C33915B18" . 5)
I closed the file and reopen then ran the CountBlockInserts and this is what I came up with.  Very little change all.  No change to Mike's blocks.  My fork truck drop by one though I did not erase any of those (would love too).
Command: CountBlockInserts
("FILLER CIP SKID" . 5)
("s802" . 4)
("s802 CIP MOdule" . 4)
("cip return" . 4)
("2.5 xw shuttle valve" . 4)
("21MPR-1xH" . 5)
("W45-100" . 5)
("13MHHMCB-1H Clamp" . 4)
("S14AWF-1 BPE Ferrule Standard-IBS" . 5)
("A$C15162F42" . 6)
("2.5 x 2.5 WE TEE" . 8)
("tank foundation" . 5)
("s-802 tank" . 5)
("A$C72CA4FE4" . 5)
("A$C353D2893" . 5)
("S14AWF-2 BPE Ferrule Standard-ISS" . 5)
("7.5HPXP" . 4)
("WK44-1-BW" . 4)
("S2S-1H BPE 90 Elbow BW" . 6)
("Scissor Lift" . 7)
("Bulk Bag conveyor" . 7)
("vulk bag with pallet" . 11)
("tank" . 4)
("REDUCER_ECC_DOWN" . 5)
("ICES-Val_BUTTERFLY" . 5)
("BRIX" . 4)
("AT1M1PLA$0$MP-009" . 4)
("AT1M1PLA$0$PI-314" . 8)
("AT1M1PLA$0$SBV" . 23)
("AT1M1PLA$0$MP-010" . 6)
("AT1M1PLA$0$LOOP" . 5)
("AT1M1PLA$0$MV-009" . 4)
("AT1M1PLA$0$MP-004" . 5)
("A$C5C1B2361" . 11)
("A$C737226D9" . 11)
("A$C0613688A" . 4)
("A$C460E5761" . 4)
("A$C33915B18" . 5)
("A$C15A444BD" . 19)
("Fork_Truck" . 6)
("RECTANG" . 4)
("spanner" . 4)
« Reply #19 on: February 11, 2009, 02:48:57 PM »
Hey Krush, can you send the drawing to mp at caddlabs dot com? I've got 15 minutes left at lunch, I'd like to examine the patient if it's alright with you.
Krushert
« Reply #20 on: February 11, 2009, 03:31:49 PM »
Sorry but in a red line meeting.  Coming at ya if still want to mess with.  Its a 9meg zipped file.
« Reply #21 on: February 11, 2009, 03:42:39 PM »
Got it, thanks. I'll look at it as soon as possible.
- Michael.
« Reply #22 on: February 11, 2009, 04:22:56 PM »
This one should give you the correct amount if you have erased a block in the current drawing ( at least it did here ).
(defun c:CountBlockInserts (/ EntData tempEnt tempData InsCntList)
    (while (setq EntData (tblnext "block" (not EntData)))
        (setq tempEnt (tblobjname "block" (cdr (assoc 2 EntData))))
        (setq tempData (entget tempEnt))
        (setq tempData (entget (cdr (assoc 330 tempData))))
        (if (setq tempData (member '(102 . "{BLKREFS")  tempData))
                (setq tempData (cdr (reverse (cdr tempData))))
                (setq tempData (vl-remove-if 'vlax-erased-p (mapcar 'cdr tempData)))
                (setq InsCntList (cons (cons (cdr (assoc 2 EntData)) (length tempData)) InsCntList))
    (foreach i InsCntList
        (print i)
Krushert
« Reply #23 on: February 11, 2009, 04:42:36 PM »
I got a
unable to get ObjectID: 1
Serge J. Gianolla
« Reply #24 on: February 11, 2009, 05:14:22 PM »
Is there anything that I can throw at?
WBlock?!
Krushert
« Reply #25 on: February 11, 2009, 06:47:49 PM »
WBlock?!
Ah the good ole stand by.  Forget about that one.
I will give it a try tomorrow when I get into work.
M-dub
« Reply #26 on: February 11, 2009, 07:19:18 PM »
WBlock?!
Just don't use a crossing window when you pick your objects or you'll ( likely ) be back in the same boat! ;)
Krushert
« Reply #27 on: February 12, 2009, 08:50:44 AM »
WBlock?!
I decided that I would try copy and pasting to new file and Wblock out objects to a new file.  Wblock reduced the file size the most as assumed.
Krushert
« Reply #28 on: February 12, 2009, 09:07:06 AM »
Now here is an interesting point.  I open the three files, ran a purge and then saved.  The "pasted" file went down in size but the other two went up a bit.
M-dub
« Reply #29 on: February 12, 2009, 09:15:07 AM »
I'm assuming that these drawings are too busy to select each component individually...
Another thing I've done in the past was to wblock out sections of the drawing at a time.  Usually in quarters.  Draw a line from midpoint to midpoint of the border, both horizontally and vertically.  Then wblock everything inside each of the four sections and see if you can find the "problem".
