Author Topic: DB losing its dynamic  (Read 5509 times)
David Hall
  • Automatic Duh Generator
« on: February 10, 2009, 08:50:31 AM »
Has anyone seen Dynamic blocks lose their dynamicness?  I can insert a DB, grip it, and not see the visibility option, yet make a copy of the DB and it has the visibility option.  I remember from somewhere a convert to static setting or option, but I cant find it anywhere
Matt__W
  • I like my water diluted.
Re: DB losing its dynamic
« Reply #1 on: February 10, 2009, 09:26:53 AM »
I've seen it happen in Civil 3D/Land Desktop 2008 when scaling up/down a DB.
Autodesk Expert Elite
Atook
  • AKA Tim
« Reply #2 on: February 10, 2009, 02:16:58 PM »
dynamicness.. I like it.
It happens to me when I even rotate my dynamic blocks, very frustrating. Glad it's not just me.
I'll be watching this thread for ideas/solutions.
David Hall
« Reply #3 on: February 18, 2009, 10:03:24 AM »
Well Autodesk solved my problem.  In Options on Open/Save tab, uncheck "Maintain Visual Fidelity" and the blocks work again.  Let me clarify, all future versions work, not ones already inserted.
Matt__W
« Reply #4 on: February 18, 2009, 10:06:30 AM »
Ummm.. yeah... NO!
I've had that unchecked since DAY ONE and I still run into this problem occassionally.  I'm glad it works for you!
David Hall
« Reply #5 on: February 18, 2009, 10:12:59 AM »
Bummer!  What is the issue?  Can you elevate it to Autodesk?
Matt__W
« Reply #6 on: February 18, 2009, 10:15:10 AM »
That's more trouble than it's worth, in my opinion.   :|
For the number of times it happens, I can live with it.
James Cannon
« Reply #7 on: February 18, 2009, 10:45:36 AM »
Seems hit or miss with me, but I've been able to open the block editor for the block that lost it, and it STILL has the paramters/actions in there... and I just tweak something and undo it (just to make it think I did something) and then 'save changes' and it brings it all back.
Sometimes, though it loses all paramteres/actions in the block definition even :\
Other times... no idea why... but it re-blocks it.  The dynamic block is there there, but it's been made into another block (dyn. block within a blocK) and I hit the ol' asplode button, and the dyn block is there for me to enjoy.
...rarely :\  But sometimes.
Thanks for the tip, though CMDRDUH, I'll keep that in mind... just had this happen the other day, to me.
dustinthiesse
« Reply #8 on: February 18, 2009, 11:14:59 AM »
This will happen if you "wblock" a dynamic block using the "objects" option instead of the "block" option and selecting the blockname from the pulldown list.  It also happens if you do this with non-dynamic blocks, but you probably don't notice it since there aren't any dynamic parameters getting "lost".
