Author Topic: How many people are changing to AUTOCAD 2010?  (Read 5866 times)
Re: How many people are changing to AUTOCAD 2010?
« Reply #15 on: February 10, 2009, 08:39:18 AM »
I voted maybe...if it's faster than '09 and our software works with it..then definitely.
You will be surprised how much 2010 has improved compared with 2009. It's much faster than 2009 and a lot of bugs are solved.
We are on subscription, but a year ago I decided to upgrade to 2008 and make 2009 shelfware because the bad performance of 2009.
Now our company will use Windows7 asap, we'll wait until then. If that wasn't the case I would switch inmedially.
That is great to hear :). Now only if our in-house irrigation software and Bentley WaterCAD work with it....then a upgrading we will go.
M-dub
« Reply #16 on: February 10, 2009, 08:44:52 AM »
I voted Yes and Maybe Later.  We're now on subscription, but we'll have to see what's going on in the office by the time it's shipped out.
I will also have to check with our EDMS software providers (Synergis Adept) to see about compatability.
Is 2010 year one of a new 'format' based on the three year cycle?
CHulse
« Reply #17 on: February 10, 2009, 08:45:39 AM »
We're on subscription wth C3D 2009 now, so we'll get there eventually... :whistle:
Cary Hulse
Urban Forestry Manager
Wetland Studies and Solutions
Civil 3D 2020 & 2023
Krushert
  • FREE BEER Tomorrow!!
« Reply #18 on: February 10, 2009, 08:58:08 AM »
IS this a requirement for 2010 to run?  Has anyone seen any system requirements for 2010?
M-dub
« Reply #19 on: February 10, 2009, 09:02:19 AM »
I sure hope not.  I don't think that would be a wise move on their part (Autodesk's).
dustinthiesse
« Reply #20 on: February 10, 2009, 09:03:37 AM »
Yes.
sinc
« Reply #21 on: February 10, 2009, 09:37:06 AM »
It sounds like Windows 7 isn't slated to be released until at least the end of the year, and maybe not even until next year.  And considering nearly all of their customers are using XP or maybe Vista, making it a requirement to have Windows 7 would be self-destructive on Autodesk's part.
But have you really known them to be that far on the cutting-edge?  (We still don't have 64-bit C3D...)
« Last Edit: February 10, 2009, 09:40:23 AM by sinc »
Matt__W
  • I like my water diluted.
« Reply #22 on: February 10, 2009, 09:38:15 AM »
I'm going to take a page out of Josh's book and post this.   :roll:
Autodesk Expert Elite
M-dub
« Reply #23 on: February 10, 2009, 09:56:13 AM »
Alright, smart a leck... Can you please post the results you found for 2010 System Requirements?  I did the exact same google search as you and didn't find it.  I hadn't finished re-reading the blogs that Kate had posted yet, though.
KewlToyZ
« Reply #24 on: February 10, 2009, 12:02:51 PM »
I need to run 2010 to see its performance advances.
Especially with auditing AEC files from clients.
2008 & 2009 tank on nonsense with AEC files so often with bad data in the drawing database.
No reasonable progress indicators for the system on its second pass either.
So far I found 2009 MEP SP2 more stable than 2008 and faster if the machine is under two years old.
But most Engineers look at it like a totally alien environment.
If 2010 finally made the palettes manageable with the cui and easily updateable without destroying the profile and reloading it.
Also the Select Similiar command available to the Vanilla platform then I would think Autodesk finally listened.
If recoverall is finally batchable I will beleive Autodesk listened to its clients.
If I can get -ExportToAutoCAD to actually bind large project files without manually pairing down into the child XREF's first and renaming them. Even better if they made it a feature of DWG True View without losing the geometry.
30 or more XREF's with 18 layouts and 4 viewports apiece is some of the horrors I have seen from clients lately.
Just because they can do it doesnt mean it is any way productive.
« Last Edit: February 10, 2009, 12:06:49 PM by KewlToyZ »
sinc
« Reply #25 on: February 10, 2009, 12:29:06 PM »
Couldn't follow this.  I haven't ever noticed any issues like this...  Can you elaborate?
KewlToyZ
« Reply #26 on: February 10, 2009, 12:33:00 PM »
If I want to update the items on a palette for networked palettes, the only way to get every workstation to recognize it is to rename the current profile and reload an updated version with the new palettes on every workstation.
The palettes, groups, and formatting are scattered throughout so many files that updating is a royal pain in the arse.
Profiles do not update everytime they are loaded, there is stuff in the Windows registry & FixedProfile.aws that just doesnt budge unless I blow it out.
Crank
« Reply #27 on: February 10, 2009, 02:45:37 PM »
It's not a requirement for 2010, official Acad2010 doesn't support Windows7 yet, because that is still in beta. But on the beta forum no bugs were reported related to the use of Windows7.
We wait because there is also money infolved to install Autocad on so many PC's. With an update at the same time as the new OS we have to install only once.
KewlToyZ
« Reply #28 on: February 10, 2009, 05:28:08 PM »
FYI
AutoCAD MEP 2009 takes almost 45 minutes to install on each workstation.
Remaking the deployment with the service packs results in all previous installations unable to repair or re-install themselves. You have to spend 30-40 minutes uninstalling, then doing an new installation for 45 minutes...
I hope the retard that made it that way chokes on his food.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #29 on: February 10, 2009, 06:47:04 PM »
FYI
< ... > takes almost 45 minutes to install on each workstation.
You could always go back to drafting on the board.    :evil:
Called Kerry in my other life
I live at UTC + 13.00
