Hi all,.
After DHATCH, DARRAY, DLEDIT, DHLINE, DBMAN....
Here it is...my New Dynamic tool.
DCLOUD v.1.1D y n a m i c C l o u dI have rethought the Revcloud function.
allowing more flexibility and options.
First, Dcloud is based on block insertion.
Why block ? because you can customise any Kind of Cloud and lineType with it.
so no more creation restriction ! you can use your own blocks !
features:
- allow user to use any block
- allow user to use diffrent geometry
rectangle
Oval
Line
Draw
- Allow user to Dynamicly scale the Block during process by pressing + or - Key
- Allow user to random color (not useful but funny
- Allow user to change all revision cloud or lintype with Block redefinition
- Allow user to create New LineType based on block insertion
to be more efficient...
Rectangle and Oval are based on snapang variable.
Line option is cool..you can create any kind !
Draw option is similar to sketch and close the Draw Loop if cursor is near the start point.
Dcloud prompt you some questions.
Command: dcloud
Block Name :
(R)ectangular/(O)val/(D)raw/(L)ine ? <R>:
Block scale:
RanDom Color ? Yes/No <N>:
Start...
while you run dcloud you will see this line below telling that you can
always use the + or - key to change the block scale.
Press (+) or (-) for Block Scale...
I have tested many Kind of block desing....there are all cool when used by Dcloud. !
Below...some Animated Gif showing you what we can do with it.
Any comment and/or suggestion will be appreciated.
I hope this will be useful fo you.
Enjoy !
Andrea.
Note: Block scale based to 1 unit and follow the INSUNITS, INSUNITSDEFTARGET and INSUNITSDEFSOURCE variables
