Author Topic: Add-Subtract Routine for Architectural/fractions  (Read 9097 times)
Re: Add-Subtract Routine for Architectural/fractions
« Reply #15 on: February 12, 2009, 01:24:18 AM »
Thanks, here is a quick fix.
I will clean up the routine tomorrow.
Biscuits
« Reply #16 on: February 12, 2009, 08:57:22 AM »
Thank you, your Lispness!
I bow before your mighty parenthesisesence!
Very intense routine and works great for my needs.
However, it would not change a whole number though.
« Reply #17 on: February 12, 2009, 10:42:06 AM »
Thanks for your kind words.
When I fix one issue another crops up, but this version seems to be close.
Still have some issues but please report any you find.
Biscuits
« Reply #18 on: February 12, 2009, 01:55:37 PM »
At this stage of the routine:
Enter increment value: <1>1 1/2
I get this error:
Error: bad argument type: numberp: nilundo Current settings: Auto = On, Control
= All, Combine = Yes
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back]
<1>: end
« Reply #19 on: February 12, 2009, 11:20:02 PM »
Well hang with me a little longer. I'll get this one nailed down yet.
Now you see why I was dragging my feet in adding support for fractions. 8-)
Biscuits
« Reply #20 on: February 13, 2009, 09:14:37 AM »
Hey Cab
You been working so hard on this.......I'm giving you the weekend off.
In the mean time, I get to shovel snow
M-dub
« Reply #21 on: February 13, 2009, 09:28:52 AM »
So many fractions!!!  :|
Wouldn't this be easier if we were all in metric?!  ;) :evil:
« Reply #22 on: February 13, 2009, 09:30:30 AM »
united we stand, divided we fall!!
oh wait, wrong thread
« Reply #23 on: February 13, 2009, 09:41:17 AM »
Metric is the way to go but I fear fractions will be with us for quite some time. :|
M-dub
« Reply #24 on: February 13, 2009, 09:43:29 AM »
Couldn't agree more.
« Reply #25 on: February 13, 2009, 04:41:01 PM »
See if this works for you.  Seems to work on the two test strings here.  Will update all numbers found within the string.
(defun ParseStringDigit (String / cnt tempStr EndList LenStr cStr bIsDigit)
    (setq LenStr (strlen String))
    (setq cnt 2)
    (setq tempStr (substr String 1 1))
    (if (<= 48 (ascii tempStr) 57)
        (setq bIsDigit T)
    (while (<= cnt LenStr)
        (setq cStr (substr String cnt 1))
        (setq cAscii (ascii cStr))
        (if bIsDigit
                (or
                    (<= 45 cAscii 57)
                    (equal cAscii 39)
                        (equal cAscii 32)
                        (<= 45 (ascii (substr String (1+ cnt) 1)) 57)
                        (vl-string-search "/" String cnt)
                        (or
                            (not (vl-string-search " " String (+ 2 cnt)))
                (setq tempStr (strcat tempStr cStr))
                    (setq EndList
                        (cons
                                (or
                                    (vl-string-search "." tempStr)
                                    (vl-string-search "/" tempStr)
                                    (vl-string-search "-" tempStr)
                                    (setq rtosType
                                            ((vl-string-search "'" tempStr)
                                                4
                                            ((vl-string-search "/" tempStr)
                                                3
                                            (t 2)
                                    (list
                                        "Real"
                                        tempStr
                                        rtosType
                                        (if (equal rtosType 2)
                                            (if (setq tempPos (vl-string-search "." tempStr))
                                                (strlen (substr tempStr (+ 2 tempPos)))
                                                0
                                            (if (setq tempPos (vl-string-search "/" tempStr))
                                                (WhatExponent (atoi (substr tempStr (+ 2 tempPos))) 2)
                                                0
                                    ) ;(distof tempStr 4)
                                (cons "Int" tempStr) ;(atoi tempStr)
                            EndList
                    (setq bIsDigit nil)
                    (setq tempStr cStr)
            (if (<= 48 cAscii 57)
                    (setq EndList (cons tempStr EndList))
                    (setq bIsDigit T)
                    (setq tempStr cStr)
        (setq cnt (1+ cnt))
    (reverse
        (cons
                    (or
                        (setq rtosType
                                    4
                                    5
                                (t 2)
                        (list
                            "Real"
                            tempStr
                            rtosType
                                    0
                                    0
                tempStr
            EndList
(defun AddNumbersTo ( inList inNum )
    (mapcar
        '(lambda (x)
            (if (equal (type x) 'LIST)
                (if (= (car x) "Real")
                    (rtos (+ (distof (cadr x) 3) inNum) (caddr x) (cadddr x))
                    (atoi (+ (atoi (cdr x)) inNum))
                x
        inList
(defun WhatExponent ( num expNum / cnt tempNum )
    (setq cnt 1)
    (setq tempNum expNum)
    (while (not (equal num tempNum))
        (setq tempNum (* tempNum expNum))
        (setq cnt (1+ cnt))
(defun c:Test (/ AddNum Sel Obj)
            (setq AddNum (getstring T "\n Enter number to add: "))
            (setq AddNum (distof AddNum))
            (not (equal AddNum 0))
            (setq Sel (entsel "\n Select entity to add to: "))
            (setq Obj (vlax-ename->vla-object (car Sel)))
        (vla-put-TextString Obj (apply 'strcat (AddNumbersTo (ParseStringDigit (vla-get-TextString Obj)) AddNum)))
« Reply #26 on: February 13, 2009, 05:05:44 PM »
Haven't tried all these but did get some errors.
abc 3.5..
abc 3 1/2
abc 3 1/2"
abc 3 1/2'
abc 3'-1"
abc 3'-1
abc 3' 1
abc 3' 1"
abc 3' 1 1/2
abc 3'-1-1/2
abc 3' 1 1/2"
abc 3' 1.5
abc 3'.5
abc 3'0.5
abc 3'-0.5
abc 3'-0.5"
abc -10
abc .5
abc 0.5
abc 1/2
abc 1/2"
abc 9 1/2
abc 1.55E+01
abc 5 A
00000
abc
abc 3' -1
Biscuits
« Reply #27 on: February 13, 2009, 05:07:58 PM »
Thanks, Tim
It's close.
Here's the test results
in adding 1 1/32
to 14 1/4 = 15 1/4
to 47 29/32 = 48 15/16
to 48 15/16 = 50
« Reply #28 on: February 13, 2009, 05:37:38 PM »
Alan,
  It does error on ones that ' distof ' doesn't know what to do with.  There are so many combinations that could be wrong, that I don't really know how one could code for all occurances, unless the code is super huge, which I was not trying to do.   :wink:  I did test most of your list though.  I can go through it again, and have a better type of error handling.
Biscuits,
  The reason why yours didn't work is two fold.  One is that the code looks at the string that is current, and then detimenes what percision is needed.  So when the base number has a lower percision than the one being added to it, it doesn't recognize it.  And the second is the way that acad translates strings->reals and reals->strings.  This is a know issue.  I'm not quite sure how to get around it at the moment.
« Reply #29 on: February 13, 2009, 06:08:15 PM »
Here we go.  This one seems to be working better.  Let me know.
Alan,
  On your old list, these are the ones it couldn't do.  Not saying that it translated them right, but these are the ones it couldn't do at all.
Command: (foreach i lst (addnumbersto (parsestringdigit i 0) 1.5))(princ)
 Could not translate: 10-1 into a number.
 Could not translate: 3'- into a number.
 Could not translate: 10-1-5 into a number.
(defun ParseStringDigit (String basePrec / cnt tempStr EndList LenStr cStr bIsDigit)
    (setq cnt 2)
        (setq bIsDigit T)
        (if bIsDigit
                (or
                    (<= 45 cAscii 57)
                    (equal cAscii 39)
                        (equal cAscii 32)
                        (or
                    (setq EndList
                        (cons
                                (or
                                    (setq rtosType
                                                4
                                                5
                                            (t 2)
                                    (setq tempPrec
                                                0
                                                0
                                    (list
                                        "Real"
                                        tempStr
                                        rtosType
                                        (if (> basePrec tempPrec)
                                            basePrec
                                            tempPrec
                            EndList
                    (setq bIsDigit nil)
                    (setq tempStr cStr)
                    (setq bIsDigit T)
                    (setq tempStr cStr)
        (setq cnt (1+ cnt))
    (reverse
        (cons
                    (or
                        (setq rtosType
                                    4
                                    5
                                (t 2)
                        (setq tempPrec
                                    0
                                    0
                        (list
                            "Real"
                            tempStr
                            rtosType
                                basePrec
                                tempPrec
                tempStr
            EndList
(defun AddNumbersTo ( inList inNum / testNum )
    (mapcar
        '(lambda (x)
                    (if (setq testNum (distof (cadr x) 3))
                        (rtos (+ testNum inNum) (caddr x) (cadddr x))
                            (prompt (strcat "\n Could not translate: " (cadr x) " into a number."))
                            (cadr x)
                    (rtos (+ (atoi (cdr x)) inNum) 2 0)
                x
        inList
    (setq cnt 1)
    (while (< tempNum num)
        (setq cnt (1+ cnt))
    cnt
(defun c:Test (/ AddNum Sel Obj LowPrec)
            (setq LowPrec
                    ((setq tempPos (vl-string-search "." tempStr))
                    ((setq tempPos (vl-string-search "/" tempStr))
                    (t 0)
        (vla-put-TextString Obj (apply 'strcat (AddNumbersTo (ParseStringDigit (vla-get-TextString Obj) LowPrec) AddNum)))
