Author Topic: How long it is to make an ELBOW ?  (Read 1932 times)
Andrea
« on: February 03, 2009, 11:16:41 PM »
command:ELLBY
First point: (pick)
Second point (pick)
Keep smile...
MickD
Re: How long it is to make an ELBOW ?
« Reply #1 on: February 04, 2009, 12:39:24 AM »
Looks good Andrea!
<thinking to self>Wish I had of learned lisp in my more formative years</self>
- John Carmack
- J.R.R. Tolkien
GDF
« Reply #2 on: February 04, 2009, 09:59:31 AM »
I can only get it to work when picking inside first to outside last. But I like it. I have one similar, but it uses four picked points (2 crossing Lines).
This will go nicely with your duct taper routine.
;;;http://www.theswamp.org/index.php?topic=25719.0
TAPER TRANSITION - 2008-10-18         Par Andrea Andreetti
Andrea
« Reply #3 on: February 04, 2009, 10:24:18 AM »
yes Gary..you'r right...
it work only when picking from inside to outside..
I miss to specify it..  :-D
too much in my head....I need an aspirin.. :lol:
Keep smile...
Adesu
« Reply #4 on: February 05, 2009, 03:01:41 AM »
I like it that code, good idea and Andrea.
As suggest
(setq p1 (getpoint "\nSelect object...from inside to outside"))
« Last Edit: February 05, 2009, 03:04:53 AM by Adesu »
Andrea
« Reply #5 on: February 08, 2009, 10:37:34 PM »
noted...and updated...thanks.  ;-)
Keep smile...
