We are using ACA 2009 and creating mode space viewports in view drawings. This works fine. The resultaint view can be draged into a sheet no problem. The problem that we are having is when placing a title mark, the model space is not highlighted as it should be. The model space title mark will pick up the correct name. Is there a variable that controles the visability of the mode space viewport?
