Author Topic: Get polar points on a compound line  (Read 2578 times)
rude dog
« on: January 31, 2009, 12:29:12 PM »
If I have a line that
is made like this:
LineStart= 1.0,1.0,0.0
LineEnd= 13.0,4.0,4.0
and I would like to define polar points from 'LineStart' at:
PtA= 4.0,1.75,1.0
PtB= 7.0,2.5,2.0
PtC= 10.0,3.25,3.0
How do I aprroach this?
Bryco
Re: Get polar points on a compound line
« Reply #1 on: January 31, 2009, 12:50:02 PM »
A plane can be made to include any 3 points.
You can make a ucs that satisfies that plane.
then you can convert the points form wcs->ucs coordinates
Now they will all have the same z value and polarpoint will work.
Now you transform the points back to world (wcs)
This is not the most efficient solution, it's probably the the solution that requires the least knowledge of math.
What are you trying to do with the points?
rude dog
« Reply #2 on: January 31, 2009, 12:58:30 PM »
Take a line that is a certain length and break it up into smaller lengths the user defines.
rude dog
« Reply #3 on: January 31, 2009, 01:07:03 PM »
Not Pretty But something along these lines:
Public Sub PickPointsPipe()
    Dim objCirc As AcadCircle
    Dim dblOD As Double
    Dim varFtpt As Variant
    Dim varSdpt As Variant
    Dim objTempLine As AcadLine
    Dim dblDist As Double
    Dim dblRunLeng As Double
    Dim dblFullStk As Double
    Dim dblAngle As Double
    Dim varLastPt As Variant
    Dim objEnts() As AcadEntity
    Dim objPipe As Acad3DSolid
    Dim varRegions As Variant
    Dim varItem As Variant
 On Error GoTo Done
  With ThisDrawing
   varFtpt = .Utility.GetPoint(, vbCr & " Pick point to start pipe: ")
   varSdpt = .Utility.GetPoint(varFtpt, vbCr & " Pick point to end pipe: ")
   Dim dblVec(0 To 2) As Double
   dblVec(0) = varSdpt(0) - varFtpt(0): dblVec(1) = varSdpt(1) - varFtpt(1): dblVec(2) = varSdpt(2) - varFtpt(2)
   Dim dblVal As Double
   dblVal = Sqr(dblVec(0) * dblVec(0) + dblVec(1) * dblVec(1) + dblVec(2) * dblVec(2))
   Dim dblVecNorm(0 To 2) As Double
   dblVecNorm(0) = dblVec(0) / dblVal: dblVecNorm(1) = dblVec(1) / dblVal: dblVecNorm(2) = dblVec(2) / dblVal
  End With
   With ThisDrawing
    Set objTempLine = .ModelSpace.AddLine(varFtpt, varSdpt)
    dblDist = objTempLine.Length
    dblRunLeng = 10#
    dblAngle = .Utility.AngleFromXAxis(varFtpt, varSdpt)
    dblFullStk = (dblDist / dblRunLeng)
    objTempLine.Delete
     varLastPt = .Utility.PolarPoint(varFtpt, dblAngle, dblRunLeng)
    Dim counter As Double
    counter = 1
    Do While dblFullStk > counter
       Set objTempLine = .ModelSpace.AddLine(varFtpt, varLastPt)
       Set objCirc = .ModelSpace.AddCircle(varFtpt, 1#)
       objCirc.Normal = dblVecNorm
    ReDim objEnts(0)
    Set objEnts(0) = objCirc
    varRegions = .ModelSpace.AddRegion(objEnts)
    Set objPipe = .ModelSpace.AddExtrudedSolid(varRegions(0), dblRunLeng, 0)
    objPipe.Update
    objTempLine.Delete
  Debug.Print varLastPt(0) & "," & varLastPt(1) & "," & varLastPt(2)
  varFtpt = varLastPt
    counter = counter + 1
    For Each varItem In objEnts
   varItem.Delete
 Next
 For Each varItem In varRegions
   varItem.Delete
 Next
    Loop
End With
Done:
 If Err Then MsgBox Err.Description
End Sub
Bryco
« Reply #4 on: January 31, 2009, 04:07:29 PM »
X = X1 + distance / dLength * DX is the math you need and you are already using it.
There is no need for angles or polar points
below is an example
Function PointOnLineAtDistance(P1, P2, Dist As Double) As Variant
    Dim P3(2) As Double
    Dim dblLength As Double
    dblLength = Length(P1, P2)
    P3(0) = P1(0) + (Dist / dblLength) * (P2(0) - P1(0))
    P3(1) = P1(1) + (Dist / dblLength) * (P2(1) - P1(1))
    P3(2) = P1(2) + (Dist / dblLength) * (P2(2) - P1(2))
    PointOnLineAtDistance = P3
End Function
rude dog
« Reply #5 on: January 31, 2009, 05:38:32 PM »
Sometime I cant see the forrest through the trees...Thank you
I was hesitant about posting what I had (because it was so scattered) and I am still learning...glad I did!
Bryco
« Reply #6 on: January 31, 2009, 05:58:28 PM »
We are all still learning.
Without posting your code I wouldn't have really understood your question.
I have often gone out of my way to resist the temptation to insert temporary objects to help with the math.
You could easily get rid of the line.
