Author Topic: polyline with different left/right width?  (Read 6051 times)
alisafei
« on: January 31, 2009, 09:27:47 AM »
hi, i have a polyline represrenting a road alignment, the centerline of that road have different left/right roadway width, so i needed this one.
if i use the global width, it is same (50%-50%) left and right side of the polyline.
is there any method to make different polyline width..like 6-left and 8-right of the selected polyline....
i think we have use the "hatch" method also, select a polyline and hatch it like forum 2 point hatching, but i dont know how to fix it exactly.
needed help?
thanks.  :-)
Re: polyline with different left/right width?
« Reply #1 on: January 31, 2009, 09:04:40 PM »
Not really a center line then is it? 8-)
No way with a polyline that I am aware of.
I suppose you could use a multi-line.
DEVITG
« Reply #2 on: February 01, 2009, 09:17:30 PM »
needed help?
thanks.  :-)
Why not offset ?
alisafei
« Reply #3 on: February 02, 2009, 12:20:34 AM »
of course, there are some other process to do it, but it need many functions and totally manually, so i searched for lisp program to automate it..
like select the polyline, set left width, set right width and done.
« Reply #4 on: February 02, 2009, 12:43:03 AM »
If you could post a sample DWF file with the center line before and an example of how
you want the roadway after running the lisp. This would help to see what you are
wanting the lisp to do.
DEVITG
« Reply #5 on: February 02, 2009, 05:11:50 AM »
I mean , offset by lisp , off course.
Please upload a dwg , with a before and after
« Last Edit: February 02, 2009, 05:40:13 AM by DEVITG »
alisafei
« Reply #6 on: February 02, 2009, 08:02:23 AM »
hi,i am trying to upload a drawing file, please look at it.
it is the same color of left/right of the polyline, it may be different color as user defined.
DEVITG
« Reply #7 on: February 02, 2009, 08:13:04 AM »
Send it to my email.
« Reply #8 on: February 02, 2009, 08:32:26 AM »
To attach a file or upload a file you will need to "Reply" to open the edit window,
then below the message click on "Additional Options". This will show more options.
Click the Browse button.
alisafei
« Reply #9 on: February 02, 2009, 08:39:37 AM »
hi, i did the same thing.
all of you can view the image which i uploaded here?
at least i can view the image which i uploaded.
DEVITG
« Reply #10 on: February 02, 2009, 08:59:41 AM »
I can see the image.
But I mean , to UPLOAD  a TRUE dwg .
« Reply #11 on: February 02, 2009, 09:00:32 AM »
Sorry, I thought you were still having trouble uploading a DWG file.
A DWG file would tell us what layers you are using, which center line is continuous and what hatch pattern you are using.
alisafei
« Reply #12 on: February 02, 2009, 09:35:06 AM »
ok friends, this time i am uploading the dwg file.
DEVITG
« Reply #13 on: February 02, 2009, 09:48:32 AM »
It is far beyond my lisp skills.
Sorry
« Reply #14 on: February 02, 2009, 10:29:43 AM »
You could offset the center line to each side at 1/2 the desired side width & set
the pline width to the desired width thereby eliminating the need for a hatch.
This would mean that you end up with two polylines. How does that sound?
