Author Topic: text size arghhh!  (Read 20800 times)
Dinosaur
Re: text size arghhh!
« Reply #15 on: May 07, 2009, 07:46:53 PM »
it would appear though that there is no standard size for thumbs either
Dent Cermak
« Reply #16 on: June 14, 2009, 05:51:05 PM »
At one time there were standards. The 2/32 and 5/32 sizes were set by a tool called the Ames Lettering Guide. This was primarily for free hand lettering.
Then as jobs got more"automated" text size was tied to the print house's font sizes, ie, 4pt,6pt, 8pt,etc. Typewriters even were usually set to 10 pt or 12 pt type. Engineers adapted to this size syatem so the could use type-set notes on their drawings on strip film. The common sizes allowed them to type notes ans add them to drawings, have fancy type set or even match those sizes with the Leroy lettering system K&E came out with. A Leroy 60 guide was the same as 6pt type or 0.06" high. (That's where the Leroy sizes L60,L80, etc. in AutoCad come from.)
In the days of quality mapping there were manuals that listed the text size and type style for eevry piece of text on a map. As new people came into the field that wanted to "do their own thing" and could not understand the spcifications, the old standards disappeared.{ A prime example of this lack of pride in craftsmanship can be clearly seen in the current U.S. Army Corps of Engineers CADD Drafting Standards Manual and the previous TM's. Maps produced prior to 1989 were suitable for framing. Maps produced after that are suitable for people with lots of birds.}
Tankman
« Reply #17 on: July 09, 2009, 03:38:18 PM »
the Standard is...
There is No One Standard!
I use a standard size unless the print is very small.
Frequently adjust title block w/ text and dimension text to suit.
We don't need to squint to see the text dialog!
Crank
« Reply #18 on: July 09, 2009, 04:18:55 PM »
the Standard is...
there is No One Standard!
In the metric world we already did have ISO-standards for text sizes when I started on the drawing board....
Willie
  • Going nowhere slowly
« Reply #19 on: July 09, 2009, 05:39:20 PM »
2.5mm = Dimensions, notes and text on drawings - if you realy have to, 2.0mm may be used.
4.0mm = Headings
Keep it straight and simple
« Reply #20 on: July 09, 2009, 11:05:18 PM »
2.5 for dim's and general notes
3.5 for minor headings/titles
5.0 for general titles
7.0 for major titles, usually the main plan on a general arrangemnet say. seldom used though
- John Carmack
- J.R.R. Tolkien
42
« Reply #21 on: July 10, 2009, 07:24:23 AM »
Ditto here
Alastair Mallett Autodesk Certified Professional
Technical Director
Hunters South Architects
chrisdarmanin
« Reply #22 on: November 10, 2009, 06:38:32 AM »
i use 2 but i think i'm straining the workers' eyes too much ;D ;D ;D
hermanm
« Reply #23 on: February 03, 2010, 09:30:03 PM »
We use 1/8" for basic text height for dimensions & annotations on steel shop & erection dwgs, which are typically Arch D (24x36).
For check prints, these are plotted reduced to Arch C (18x24), which makes text on check prints (2/3)(1/8") = 0.0833" , just slightly smaller than 3/32" - very easy to read text on check prints.
Typical scales for shop dwgs are:
1 1/2" = 1' (1:8 )
1" = 1' (1:12)
3/4" = 1' (1:16)
1/2" = 1' (1:24)
Typical scales for erection dwgs are:
1/2" = 1' (1:24)
1/4" = 1' (1:48)
3/16" = 1' (1:64)
1/8" = 1' (1:96)
etc.
So, it is easy to calculate the standard text height as an integer representing the inverse of the scale.
For example, the text height for 1" = 1' is 12 eighths, 12/8, or 1 1/2"
I never actually need to calculate the text height, because I wrote a LISP routine to calculate it for me many years ago, based on this scaling function:
;;--------------------- tktn_getscl--------------------------------------
;;      Purpose: calculate scale factor
;;      Uses:    nothing
;;      Returns: sf
(defun tktn_getscl( )
  (cond ((= 1 (getvar "TILEMODE")) (getvar "DIMSCALE"));tiled space
        ((= 1 (getvar "CVPORT")) 1.0);in paper space
     ;; in a viewport
        (T
          (last (trans '(0 0 1.0) 3 2));calc scale factor
  );cond
);end tktn_getscl
The basic text height is calculated as:
(* (tktn_getscl) (getvar "DIMTXT"))
and larger or smaller "standard" sizes are calculated from values in a user-defined list:
;;initialize NTEXTSCALES (global)
(setq NTEXTSCALES (list '(JUMBO .  2.0) '(BIG . 1.5) '(MEDIUM . 1.25) '(NORMAL . 1.0)
                        '(SMALL . 0.75) '(TINY . 0.5)))
NTEXT is available free at my website:
www.tktn.com
Alan Cullen
« Reply #24 on: February 04, 2010, 04:22:12 AM »
And that, Mick, has been the Aussie standard for as long as I can remember
« Reply #25 on: February 04, 2010, 04:42:07 AM »
true dat, BUT... we have been moving to 3.5 for dim text and notes as the client/s like to look at drgs at A3 size and a B1 is hard to read for some.
I'm not a real fan of this but I'm not paying the bills although for straight steel detailing (not general arrangements etc) I use 2.5 or 3mm as 3.5 is just oo big for tight or busy details.
Really though, 3 is fine and I don't care as long as every one uses the same standard. :)
- John Carmack
- J.R.R. Tolkien
« Reply #26 on: February 04, 2010, 04:50:21 AM »
Which is fine untill A0's are issued as A1's and B1'a as A1's and A1's ( or all) as A3's ... and the SteelShop foreman comes in and asks why you do such small text on HIS drawings.
on original drawings :
2.5 for reference notes
3.0 or 3.5 dimensions
5.0 titles
7.0 big stuff
... or be prepared to wear a hammer aroung the ears :)
« Reply #27 on: February 04, 2010, 04:56:46 AM »
Quite often the steel shop foreman with give the fabby an A3 and have full size copies in the office which they can refer to if something isn't clear (you lose a lot of hidden line and edge details with reduced drgs). Nothing worse than a half burnt drg :)
With 3mm text this system works fine up to B1's then we would go 3.5 but we rarely if ever go larger than B1.
- John Carmack
- J.R.R. Tolkien
Alan Cullen
« Reply #28 on: February 04, 2010, 08:42:36 AM »
Whatever happened to stock standard ISO sheets? Basically A1 and A3? If the fabricator has a problem with reading an A3, then someone should tell him that A3 is a pretty drawing only, not a fabrication/construction drawing. Construction drawings are A1, which they have all been issued.
If a contractor phones me and says he can't read the drawing, then I tell him to go and look at the contract drawings and stop wasting my time. I refuse to clutter up a drawing with oversized text.
And therein is my input into text size. I will not compromise my standards to suit a short sighted foreman who likes A3 just because they are handy.  :lmao: :lmao: :angel:
wwhittle
« Reply #29 on: February 19, 2010, 06:02:33 AM »
Jeez. Inches everywhere. try mm.
1.5mm - xref text
1.8mm - most notes & text
2.5mm - headings
3.5mm - Bold headings.
Above follows the old iso pen sizes. Before CAD lol.
Not sure what the equivilant is in Inches.
