Some of my commonly-used extension methods:
// Should be self-explainatory:
public static class DoubleExtender
public static string ToDistance( this double value )
return Converter.DistanceToString( value, DistanceUnitFormat.Current, -1 );
public static string ToDistance( this double value, DistanceUnitFormat format, int precision )
return Converter.DistanceToString( value, format, precision );
// TODO: ToAngle()
public static class PolylineHelper
public static Curve GetCurveAt( this Polyline pline, int index )
Entity ent = pline.GetSubentity(
new FullSubentityPath(
new ObjectId[] { pline.ObjectId },
new SubentityId( SubentityType.Edge, index + 1 ) ) );
if( ent != null )
Curve curve = ent as Curve;
if( curve != null )
return curve;
ent.Dispose();
return null;
public static Curve GetCurveAt( this Polyline pline, Point3d pointOnSegment )
return GetCurveAt( pline, (int) Math.Truncate( pline.GetParameterAtPoint( pointOnSegment ) ) );
public static Curve GetCurveNearestTo( this Polyline pline, Point3d point )
return GetCurveAt( pline, pline.GetClosestPointTo( point, false ) );
public static Curve3d GetCurve3dAt( this Polyline pline, int index )
switch( pline.GetSegmentType( index ) )
case SegmentType.Arc:
return pline.GetArcSegmentAt( index );
case SegmentType.Line:
return pline.GetLineSegmentAt( index );
default:
throw new InvalidOperationException( "Unknown segment type" );
public static Curve2d GetCurve2dAt( this Polyline pline, int index )
return pline.GetArcSegment2dAt( index );
return pline.GetLineSegment2dAt( index );
default:
public static class BlockReferenceExtensionMethods
public static string DefinitionName( this BlockReference target )
if( target.IsDynamicBlock )
using( BlockTableRecord obj = target.DynamicBlockTableRecord.Open( OpenMode.ForRead, true, true ) as BlockTableRecord )
return obj.Name;
return target.Name;
/// This class allows you to tell if a List<T>
/// was modified between two points in time:
/// Example:
/// List<int> myList = new List<int>();
/// myList.Add( 1 );
/// myList.Add( 2 );
/// myList.Add( 3 );
/// int version = myList.GetVersion();
/// SomeVirtualMethod( myList ); // called method may modify the list
/// if( myList.IsModified( version ) )
/// Console.WriteLine("SomeVirtualMethod() changed the list");
public static class ListExtender
public static int GetVersion<T>( this List<T> list )
FieldInfo fi = typeof( List<T> ).GetField( "_version", BindingFlags.Instance | BindingFlags.NonPublic );
if( fi != null )
return (int) fi.GetValue( list );
throw new InvalidOperationException();
public static bool IsModified<T>( this List<T> list, int oldVersion )
return list.GetVersion<T>() != oldVersion;
public static class QueueExtender
public static void Enqueue<T>( this Queue<T> queue, IEnumerable<T> items )
foreach( T item in items )
queue.Enqueue( item );
public static void Enqueue<T>( this Queue<T> queue, IEnumerable items )
foreach( object item in items )
queue.Enqueue( (T) item );
/// The most useful extension methods I know of, with the
/// caveat that they're probably unsuitable in performance-
/// critical scenarios.
/// Example:
/// BindingFlags flags = BindingFlags.Public | BindingFlags.InvokeMethod | BindingFlags.Static;
/// Instead of doing this:
/// bool isStatic = ( flags & BindingFlags.Static ) == BindingFlags.Static;
/// You can instead do this:
/// bool isStatic = flags.Includes( BindingFlags.Static );
/// Or:
/// bool isStatic = flags.And( BindingFlags.Static );
public static class EnumExtender
public static bool Includes( this Enum target, Enum flags )
if( target.GetType() != flags.GetType() )
throw new ArgumentException( "Enum type mismatch" );
long a = Convert.ToInt64( target );
long b = Convert.ToInt64( flags );
return (a & b) == b;
public static bool IncludesAny( this Enum target, Enum flags )
return ( Convert.ToInt64( target ) | Convert.ToInt64( flags ) ) != 0L;
public static bool And( this Enum target, Enum flags )
return Includes( target, flags );
public static bool Or( this Enum target, Enum flags )
return IncludesAny( target, flags );
