Author Topic: two questions about selection  (Read 1896 times)
vladimirzm
« on: January 27, 2009, 04:35:12 PM »
hi
1º is there any way to know which objects were selected by SHIFT+SELECT?. i mean, i have a selection set ("final-selset") highlighted then i need remove objects from this set through another selection ("temp-selset"), the problem is what i need it works "autocad-like": SHIFT+SELECT must create another selection set to do some test before remove.
2º is there any way to simulate ssget ":S" (single method) through VisualLisp, by SelectionSet object?
Re: two questions about selection
« Reply #1 on: January 27, 2009, 04:52:37 PM »
1st look at (setq ss(ssgetfirst))
2nd whay would you not use the ssget & convert to vl?
vladimirzm
« Reply #2 on: January 27, 2009, 05:06:57 PM »
1 well i'll see again ssgetfirst if i lost something.
2 actually that's what i do but i was wondering if there's a way to avoid this
DEVITG
« Reply #3 on: January 28, 2009, 11:44:08 AM »
about point 2 , once I read in Cadalist , that is better not to use SelectionSet object .
i think it was
;;;Author
;;;R. Robert Bell
What I do is to convert th SS in a OBJ list  , so it can be handle by foreach ,
Often I use the
VLA-GETACTIVESELECTIONSET after a SSGET .
But I feel confort with a OBJ LIST
