Author Topic: validate layer names?  (Read 2046 times)
mkweaver
« on: January 27, 2009, 08:58:17 AM »
Isn't there a lisp function that will check a layer/block name for validity?  I've searched help, here on the swamp, and the autodesk newsgroups, but haven't found what I'm looking for.  Have I missed something?
Pointers appreciated.
Mike
lispman21
Re: validate layer names?
« Reply #1 on: January 27, 2009, 08:59:57 AM »
Maybe something like this
      (if (tblsearch "layer" "layername")
(command "-layer" "s" "layername")
(command "-layer" "m" "layername" "c" "red" "layername" "")
      );;end of if
mkweaver
« Reply #2 on: January 27, 2009, 09:11:26 AM »
I'm not checking to see if the layer exists, I want to know if the layer name is valid - will I get an error if I try to create a layer with this name?
« Reply #3 on: January 27, 2009, 09:17:31 AM »
(snvalid sym_name [flag])
mkweaver
« Reply #4 on: January 27, 2009, 10:14:59 AM »
Thats what I was looking for!
Thank you much!
« Reply #5 on: January 27, 2009, 11:14:35 AM »
You're most welcome Mike.
(defun IsBliss ( question gratitude )
    (and
        (IsEasy question)
        (IsGreat gratitude)
adalea03
« Reply #6 on: January 31, 2009, 08:31:51 AM »
    (and
        (IsEasy question)
        (IsGreat gratitude)
While I envy your mastery, coding seems to have become more than a second language, heh MP?
Tony
« Reply #7 on: January 31, 2009, 09:08:13 AM »
T
