Author Topic: Working in metric (sort of)  (Read 12116 times)
CADaver
Re: Working in metric (sort of)
« Reply #15 on: January 26, 2009, 09:52:15 PM »
even computers are metric lol.
Kilobyte = 10^3 bytes
Megabyte = 10^6 bytes
Gigabyte = 10^9 bytes
Terrabyte = 10^12 bytes
a swing and a miss, the "metric" notation here is merely an approximation of the actual binary number   (kilobyte=1028, not 1000)
A question for those in the lands of metric, are not many things measure in centixxxx somethings??  Like engine displacement?
Alan Cullen
« Reply #16 on: January 26, 2009, 10:15:00 PM »
Possibly, I have heard of cu.cm before, but here in Australia, most engine sizes are in litres. Mine is a 3.6 Lt V6.
CADaver
« Reply #17 on: January 26, 2009, 10:16:00 PM »
Even cycles??
Strucmad
« Reply #18 on: January 26, 2009, 10:28:59 PM »
 :lmao:  Your on the ball Cadaver... I was waiting for someone to pick me up on that   :lmao:
Glad to see you back mate....
Yeah bikes are measured in cc 250, 500 1000..
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #19 on: January 27, 2009, 12:13:30 AM »
Actually, since we're nitpicking,  a kilobyte is 1,024 bytes not 1028 :)
Called Kerry in my other life
I live at UTC + 13.00
« Reply #20 on: January 27, 2009, 04:42:12 AM »
reminded me of this (recent)  : Converting to Metric
Some helpful tables and reference points
http://xkcd.com/526/
Willie
  • Going nowhere slowly
« Reply #21 on: January 27, 2009, 05:37:28 AM »
If you can count to ten, you can use metric units... :-D
Soli Deo Gloria | Qui Audet Adipiscitur
Windows 8  64-bit Enterprise | Civil 3D 2015 and 2016| ArcGIS 10.1
Yogi Berra : "I'd give my right arm to be ambidextrous."
Matt__W
  • I like my water diluted.
« Reply #22 on: January 27, 2009, 08:09:33 AM »
MJ whoever put Centimetres in that table should be shot....There is no such thing, and they should never be spoken about.. :lol: :wink: :lmao:
that would be courtesy of our friends at autodesk
The same folks who have LIGHT YEARS as an option for insertion scale.   :lol:
Autodesk Expert Elite
Matt__W
« Reply #23 on: January 27, 2009, 08:14:01 AM »
Have been a loooooooooooooooooooong time that I stop doing drafting in metric (metros).... maybe this might help you:
Thanks!  Just what I needed.
Daniel J. Ellis
« Reply #24 on: January 27, 2009, 08:30:53 AM »
Our European friends use centimeters for architectural/engineering/etc. work, that's probably why Autodesk included them.
dJE
dJE
dgorsman
« Reply #25 on: January 27, 2009, 02:12:49 PM »
Its used in some scientific calculations in some circles, aka the "cgs" system of units: centimeters/grams/seconds.  I think the "dynes" unit of measurement is based on cm rather than meters, but I could be off on that.  High school was a loooong time ago.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
CADaver
« Reply #26 on: January 27, 2009, 11:10:28 PM »
Crud, you're right.  Bit o' trivia though, this being a CAD site and all, anyone care to guess where my brain errantly picked up the 1028??
CADaver
« Reply #27 on: January 27, 2009, 11:13:03 PM »
Look at yer fingers, even God thinks in metric.
... after thinkin' about the folks who post here, I'll re-phrase ... "Look at the fingers of NORMAL people ..."
Tuoni
  • I do stuff, and things!
« Reply #28 on: January 27, 2009, 11:15:14 PM »
dJE
Not any engineer that I know, nor one that was trained by my family....
The SI units in metric are mm and m; cm are a lazy-man invention which has no place in measurements.
Tuoni
« Reply #29 on: January 27, 2009, 11:18:08 PM »
Meeeeowwww...
I guess you've missed the trollin', huh?
