Author Topic: Working with old plats  (Read 6256 times)
Re: Working with old plats
« Reply #15 on: January 26, 2009, 02:59:06 PM »
I would try a radius of 60' on the larger curve.  Actually would try offestting the 10' radius across the street first, and see how that worked.
I agree Bob, that follows the intent of the plat.
Fair certain those curves are NOT concentric. Or the lot dimension wouldn't be 80'
Spike Wilbury
« Reply #16 on: January 26, 2009, 03:20:55 PM »
from an outsider... my stab  :-P
« Reply #17 on: January 26, 2009, 03:30:29 PM »
looks like you decided to hold the wrong line...
pkohut
« Reply #18 on: January 26, 2009, 03:32:53 PM »
 :lmao:
« Reply #19 on: January 26, 2009, 03:46:49 PM »
it think it might be more or less like this from the information (NOT) given...
Spike Wilbury
« Reply #20 on: January 26, 2009, 04:06:01 PM »
That's is not tangent to the right line and if it is break in two, it won't measure 68.25 + 15
AFIK
Spike Wilbury
« Reply #21 on: January 26, 2009, 04:10:02 PM »
AFIK
and unless here in the US and back then, they dimensioned both arcs as a single lot front... then maybe it is closed
« Reply #22 on: January 26, 2009, 04:16:19 PM »
from what little information present one must work on a couple of premise;
that the distance shown is the total lot frontage,
or the distance show is just the large arc length,
and or pray that the surveyors actually unearth the lot corner where those two arcs meet....
and notice my disclaimer...More OR Less...
Spike Wilbury
« Reply #23 on: January 26, 2009, 04:20:54 PM »
I know Michael.... :)
« Reply #24 on: January 26, 2009, 04:31:45 PM »
It would be far easier to solve had they given us the two small arc lengths, as then there would only be one solution.
Spike Wilbury
« Reply #25 on: January 26, 2009, 04:36:30 PM »
the calc's are no problem... in my case is that I'm neophyte about civil stuff here in the US..... :-(
« Reply #26 on: January 26, 2009, 04:46:47 PM »
trust me, the calc's are the problem....I have a version here that nets 76.16' across those lots...
however there are still far too many ass   umptions in there for my liking...
for the want of TWO chord angles....
Dinosaur
« Reply #27 on: January 26, 2009, 11:29:08 PM »
Here is my best solution . . . The numbers from the NE corner of the section seemed to indicate it was assumed 90 degrees with cardinal direction so I worked back from there and threw the wedge into the West line of the quarter/quarter and used the odd distances to set the bearing for the N/S roads.  The frontage of the lot doesn't quite fit but it looks like the intent was to have 35' radius reverse curves using this solution
Spike Wilbury
« Reply #28 on: January 27, 2009, 12:12:47 AM »
And my latest one...
« Reply #29 on: January 27, 2009, 11:10:48 AM »
I hate to say it DinØ, I like something on the order of what LE has done as the relationship of the arcs, is nearer the original image, FWTW.   :wink:
