Author Topic: Help me find the name  (Read 4069 times)
Luke
« on: January 23, 2009, 05:35:36 PM »
Look in this drawing.  I've drawn a green box around the block I'm interested in....
I can only find the temp names *U346.  Can comebody tell me how to find the original or how to get into this block in the dynamic block editor.
Re: Help me find the name
« Reply #1 on: January 23, 2009, 06:17:27 PM »
the single biggest reason one should NOT copy blocks, or use copy clip....are the resultant UNAMED blocks..
« Reply #2 on: January 23, 2009, 06:56:57 PM »
Give this a whirl...if it crashes your session, try running..close the drawing saving changes, then reopen and your block should be ok.
(vla-put-name
  (vla-item (vla-get-blocks
      (vla-get-activedocument
(vlax-get-acad-object)
    (vla-get-effectivename
      (vlax-ename->vla-object (car (entsel)))
  "mynewblock"
Luke
« Reply #3 on: January 26, 2009, 08:28:10 AM »
that did it.  Thanks ronjonp
« Reply #4 on: January 26, 2009, 09:58:40 AM »
You're welcome :)
