I'm trying to write a short code for fillet'ing polylines with different radii, all working in a loop, but it doesn't want to work when I select 2 polylines. Lines are OK, line+poly is also fine but 2 polys just won't go through. I can do it manually but not with this code:
(setq
#filletr1 (edreal "Enter first radius: " #filletr1 3)
#filletrd (edreal "Enter change in radius: " #filletrd 3)
filletr2 #filletr1
(while T
(setq ET1 nil ET2 nil)
(setq ET1 (entsel "\npick first: "))
(while (= ET1 nil)
(setq ET2 (entsel "\npick second: "))
(while (= ET2 nil)
(setvar "filletrad" filletr2)
(command "._fillet" ET1 ET2)
(setq filletr2 (+ #filletrd filletr2))
I've tried using car and cadr around ETs but it doesn't seem to have much effect.
What am I doint wrong?
OK apparently I did something wrong while trying multiple versions. Writing
(command "._fillet" (cadr ET1) (cadr ET2))
actually works! But... why is it needed?
