Author Topic: Objectdbx.. image path  (Read 7523 times)
HelpLispinSeattle
« on: January 14, 2009, 11:45:33 AM »
Hello,
I am just learning autolisp. I picked a code from this site using ObjectDBX.
I'm trying to repath all the images in a drawing to "..\\Image\\" folder.
What am I doing wrong?.
usage..(PutImagePath "c:\\temp\\test.dwg" "..\\Image\\")
(defun PutImagePath (File Newpath / odbxSaveFlag file odbx index yetRedefine saveError objBlock image iname iextn imagename ipath)
; main
      (if (< (atoi (substr (getvar "ACADVER") 1 2)) 17)
        (setq odbx (vlax-get-or-create-object "ObjectDBX.AxDbDocument"))
        (setq odbx (vlax-get-or-create-object (strcat "ObjectDBX.AxDbDocument." (substr (getvar "ACADVER") 1 2))))
      ; main loop
       (if (vl-catch-all-error-p (vl-Catch-All-Apply '(lambda () (vla-open odbx (strcat file)))))
          (alert (strcat "Sorry..This drawing is open :\n" file))
          (setq odbxSaveFlag nil)
        (vlax-for lo (vla-get-Layouts odbx)
                (vlax-for i (vla-get-Block lo)
                    (if (= (vla-get-ObjectName i) "AcDbRasterImage")(progn
        (setq image (vla-get-ImageFile i))
        (setq iname (vl-filename-base image))
        (setq iextn (vl-filename-extension image))
        (setq imagename (strcat iname iextn))
        (setq ipath (strcat newpath imagename))
        (vla-put-ImageFile i ipath)
                    );if
         (if odbxSaveFlag (vla-saveas odbx (strcat file)))
         );progn
      );if vl-catch
      (acet-ui-status)
     (vlax-release-object odbx)
   );progn
; variables set
 (setq
    saveError *error*
    *error* errorFunction
    index 0
; error function
(defun errorFunction ()
  (setq *error* saveError)
  (acet-ui-status)
  (if (and objBlock (not (vlax-object-released-p objBlock))) (vlax-release-object objBlock))
  (if (and odbx (not (vlax-object-released-p odbx))) (vlax-release-object odbx))
  (foreach x '( odbxSaveFlag file odbx index yetRedefine saveError objBlock image iname iextn imagename ipath)
    (set x nil)
  (gc)
Re: Objectdbx.. image path
« Reply #1 on: January 14, 2009, 12:17:05 PM »
I didn't test it; just an FYI.
What is it not doing?  It looks like it should work.
HelpLispinSeattle
« Reply #2 on: January 14, 2009, 12:35:49 PM »
It gives me this error message..
error: An error has occurred inside the *error* functiontoo many
arguments
It works okay till "(vla-put-ImageFile i ipath)".
« Reply #3 on: January 14, 2009, 12:56:08 PM »
That line works, it just returns nil, but it does put the new path; at least here in a simple test it did.  I think the error might be here
(if odbxSaveFlag (vla-saveas odbx (strcat file)))Why are you trying to make a new path for the file?  If not, then it should just be
(if odbxSaveFlag (vla-saveas odbx file))
HelpLispinSeattle
« Reply #4 on: January 14, 2009, 01:16:12 PM »
Tim,
Still didn't not work.
« Reply #5 on: January 14, 2009, 01:35:53 PM »
This works.  Try and find what I did different.  If you can't, I'll try and remember.  Can't point it out right now, sorry.
; main
    (setq odbx
        (if (< (atoi (setq oVer (substr (getvar "acadver") 1 2))) 16)
            (vla-GetInterfaceObject (vlax-get-acad-object) "ObjectDBX.AxDbDocument")
            (vla-GetInterfaceObject (vlax-get-acad-object) (strcat "ObjectDBX.AxDbDocument." oVer))
      ; main loop
       (if (vl-catch-all-error-p (vl-Catch-All-Apply '(lambda () (vla-open odbx file))))
          (setq odbxSaveFlag T)
                    );if
         );progn
      );if vl-catch
      ;(acet-ui-status)
HelpLispinSeattle
« Reply #6 on: January 14, 2009, 01:45:33 PM »
Tim,
You made it work!..Thank you! Thank you!...I will try to find what you
did differently and learn from it.
HelpLispinSeattle
« Reply #7 on: January 16, 2009, 09:27:15 AM »
Tim,
The code works good, but sometimes I get this error message
on some of my drawings.."error: Automation Error. File access error"
When I open the drawing I ran the code with I get an alert box saying
it is currently used by me. (When I ran the code I have only one (1) drawing
open). I have to quit autocad and fire it up again, then the drawing is okay.
Any ideas why sometimes it does not work?
« Reply #8 on: January 16, 2009, 11:03:53 AM »
The error message would mean to me that someone has the drawing open.  But you shouldn't get the error, since that part of the code is wrapped up in a ' vl-catch-all-apply ' call.
The second part is most likely because it isn't closing the drawing, and releasing the ObjectDBX object.  Which shouldn't happen either, unless it is error'ing with the portion of the code about the images.
To fix both of these problems, you could create a local error function, just for this function.  Within that section, you will see if the ODBX object equals anything, and if so, release it and set it to nil.  I know if you have it in the local vars list this will happen, but I got in the habit of just setting it anyway.
Hope that is enough to get you going with trying to code it yourself.  If you get stuck, let us know, and we can help you some more.
HelpLispinSeattle
« Reply #9 on: January 16, 2009, 11:24:51 AM »
I'm new with autolisp, but I understand you correctly you mean this? (Which came with
the code I picked up from this site.)
; variables set
 (setq
    saveError *error*
    index 0
; error function
  (acet-ui-status)
    (set x nil)
  (gc)
« Reply #10 on: January 16, 2009, 11:32:24 AM »
Kind of, but not really.  The way that is currently coded, it is not a local error function.  That is the old style of error function handling.  Now one use a local like
(defun c:SomeName ( / localVariables And ErrorFunction *error* )
    (defun *error* ( msg )
        .... error function code here
   ..... normal code here
This way the error function ( *error* ) will only be known for the function ' SomeName '.  The only thing is you have to name your error function ' *error* '.
HelpLispinSeattle
« Reply #11 on: January 16, 2009, 12:17:41 PM »
How about this?...(I'm really guessing at this point).
(defun PutImagePath (File Newpath / file newpath odbxSaveFlag  odbx objBlock image iname iextn imagename ipath *error* )
;error function
(if (= msg "error: Automation Error. File access error") (vlax-release-object odbx))
;normal code
    (setq odbx
                    );if
         );progn
      );if vl-catch
      ;(acet-ui-status)
« Reply #12 on: January 16, 2009, 12:40:44 PM »
See if this works for you.  I changed the error function a little, and the ' if ' call.  This is how I would use ' vl-catch-all-apply '.  I call the error function with no arguments, so that you only have to have code in one place to release the ODBX object.  Just a little simpler.  And I formatted the code to the way I like to look at it.
(defun PutImagePath (File Newpath / oVer odbxSaveFlag  odbx image iname iextn imagename ipath *error* )
    ;error function
        (if odbx (vlax-release-object odbx))
        (if msg
            (prompt (strcat "\n Error-> " msg))
;normal code
    (setq odbx
    (if (vl-catch-all-error-p (vl-Catch-All-Apply 'vla-open (list odbx file)))
                    );if
        );progn
    );if vl-catch
    ;(acet-ui-status)
    (*error* nil)
HelpLispinSeattle
« Reply #13 on: January 16, 2009, 01:13:34 PM »
I think I understand what you did. And regardless of what the error "msg" you
released the object.
I opened the drawing and this time it was not a read-only. But it did not
repathed the image. There was a new error rmessage
Error-> ActiveX Server returned an error: Parameter not optional
« Reply #14 on: January 16, 2009, 01:24:50 PM »
In the error function add ' (vl-bt) '.  Then paste the whole command line prompt.  This will tell me where the code is erroring, as I'm not sure why you would get that message, as I didn't change anything really.
