Author Topic: Assignment to protected symbol error and AecXBase lib  (Read 4804 times)
commodore
« on: January 13, 2009, 10:03:21 AM »
Is there something wrong with my code or with the AecXBase.tlb library that when I run this I immediately get 2 "Assigment to protected symbol:" errors on "paec-get-linewieght" and "paec-put-lineweight"
It does not matter what prefix I try.
I am using MEP2008
Anyone else care to try and tell me their results?
(vlax-Import-Type-Library
:tlb-filename "AecXBase.tlb"
:methods-prefix "maec-"
:properties-prefix "paec-"
:constants-prefix "caec-"
Matt__W
  • I like my water diluted.
Re: Assignment to protected symbol error and AecXBase lib
« Reply #1 on: January 13, 2009, 10:09:38 AM »
Also using MEP 2008...
Command: (vlax-Import-Type-Library :tlb-filename "AecXBase.tlb":methods-prefix "maec-":properties-prefix "paec-":constants prefix "caec-")
T
I dunno... :|
Autodesk Expert Elite
Spike Wilbury
commodore
« Reply #3 on: January 13, 2009, 02:50:48 PM »
I guess I should add MEP SP1
Whats the date on your AecXBase.tlb file?
Mines 9/7/2007 9:17 AM
T
I dunno... :|
« Last Edit: January 14, 2009, 07:02:10 AM by commodore »
commodore
« Reply #4 on: January 14, 2009, 08:07:52 AM »
Load the Vlide and try again
It seems that this is what causes the problem on my end.
If I dont start the vlide it runs fine.
T
I dunno... :|
« Reply #5 on: January 14, 2009, 08:51:26 AM »
Yeah vlide and protected var assignment is flaky .. heck even the Autodesk expresstools in previous versions wouldn't load properly if the vlide was open.
Spike Wilbury
« Reply #6 on: January 14, 2009, 10:14:26 AM »
Did you tried with this:
(pragma '((unprotect-assign paec-get-linewieght paec-put-lineweight)))
:constants-prefix "caec-")
(pragma '((protect-assign paec-get-linewieght paec-put-lineweight)))
As in my previous post ?
commodore
« Reply #7 on: January 14, 2009, 01:18:39 PM »
At first no, but now I have and the result is the same error.
What is pragma? I cant find any documentation on this.
commodore
« Reply #8 on: January 14, 2009, 01:20:55 PM »
Its not even if the vlide is open. Its if the vlide HAS been OPENED.
Even if I close the vlide I get the error.
Matt__W
« Reply #9 on: January 14, 2009, 01:28:15 PM »
Same!   :|
« Reply #10 on: January 14, 2009, 01:32:45 PM »
That is correct, because the error trap from the VLIDE stays resident even after the VLIDE is closed.
You can change the notification by selecting Tools-->Environment Options-->General Options [General Tab] (in the VLIDE)
There is an option for "SETQ to protected symbols" .. if you set it to transparent, the error notification goes away
commodore
« Reply #11 on: January 15, 2009, 06:36:15 AM »
Thanks for all the info!
