Author Topic: "sort" of a request  (Read 6728 times)
HelpLispinSeattle
"sort" of a request
« on: January 12, 2009, 01:31:26 PM »
I've been searching every where for a lisp "sort" function . We archive are drawings
in this folder format.
12-08-07   75% Design Development
08-08-07   Design Development
03-08-08   Progress Print
07-08-08   For Construction
12-08-08   For Permit & Pricing
01-08-09   Addendum No.1
But if I use "acad_strlsort"  (I've also tried vl-sort, win_sort & dos_sortlist)
it returns....
I would like it to sort by year & chronologically....
Can somebody help?
uncoolperson
Re: "sort" of a request
« Reply #1 on: January 12, 2009, 01:46:40 PM »
you could write something to reformat the date to year-month-day, then sort, the unreformat and return the list
« Reply #2 on: January 12, 2009, 01:47:38 PM »
There's 2 approaches (1) normalize the data so a normal sort works properly (2) create a custom sort.
While it's fun to do the latter, it means every time you have wonky data you have to write a new sort function, and as easy as it is to do the latter, I'd recommend the former.
Having said that, here's a sort routine do do what you want to dispel the notion I'm just being a curmudgeon.
(setq lst
        "12-08-07   75% Design Development"
        "08-08-07   Design Development"
        "03-08-08   Progress Print"
        "07-08-08   For Construction"
        "12-08-08   For Permit & Pricing"
        "01-08-09   Addendum No.1"
(defun foo ( lst )
    (   (lambda (f) (vl-sort lst '(lambda (a b) (< (f a) (f b)))))
        (lambda (x) (strcat (substr x 7 2) (substr x 1 2)(substr x 4 2)))
(mapcar 'print (foo lst))
I could have converted the date strings to numerical values and sorted on same but in the interests of brevity I didn't.
Edit: Revised per this post.
« Last Edit: January 12, 2009, 04:23:52 PM by MP »
dustinthiesse
« Reply #3 on: January 12, 2009, 02:01:38 PM »
I really need to learn the lambda function cuz that right there just blows me away.
I can't even process what that function is doing.  :-o
kpblc
« Reply #4 on: January 12, 2009, 02:07:04 PM »
(setq value '("12-08-07   75% Design Development"         "08-08-07   Design Development"
              "03-08-08   Progress Print"                 "07-08-08   For Construction"
              "12-08-08   For Permit & Pricing"           "01-08-09   Addendum No.1"
      ) ;_ end of setq
(defun test (lst)
  (vl-sort
    lst
    (function
      (lambda (a b)
        (< (strcat (substr a 7 2) (substr a 4 2) (substr a 1 2))
           (strcat (substr b 7 2) (substr b 4 2) (substr b 1 2))
           ) ;_ end of <
        ) ;_ end of lambda
      ) ;_ end of function
    ) ;_ end of vl-sort
  ) ;_ end of defun
;; (test value)
Sorry for my English.
« Reply #5 on: January 12, 2009, 02:08:37 PM »
It's nothing magical, maybe this will help.
HelpLispinSeattle
« Reply #6 on: January 12, 2009, 02:14:18 PM »
Wow!...Thank you guys. And I though it would be
really a long long code.
« Reply #7 on: January 12, 2009, 02:15:55 PM »
« Reply #8 on: January 12, 2009, 02:26:15 PM »
Zing!!
Welcome to theSwamp HelpLispinSeattle.
dustinthiesse
« Reply #9 on: January 12, 2009, 02:37:05 PM »
I get the smaller uses of it, but I just can't seem to wrap my head around this one.  Maybe I just need try using it more in my own coding and I will get more comfortable with it.  Right now it's like a scary monster to me.
HelpLispinSeattle
« Reply #10 on: January 12, 2009, 03:31:44 PM »
MP,
I have a project that has around 150 archived folders. "Foo"  got the days & year
correctly but not the months (the first two characters). They did not sort correctly.
« Reply #11 on: January 12, 2009, 04:00:00 PM »
Just to be clear, what does each pair of numbers in your date string represent?
HelpLispinSeattle
« Reply #12 on: January 12, 2009, 04:11:16 PM »
example:
Today's date-> 01-12-09   Bla bla bla
01=month
12=day of month
09=year
« Reply #13 on: January 12, 2009, 04:18:30 PM »
I had transposed the month and day. Try this:
(defun foo ( lst )
And for <more> obfuscated fun, this:
(defun foo ( lst )
    (   (lambda (f1 f2) (vl-sort lst 'f1))
        (lambda (a b) (< (f2 a) (f2 b)))
:D
HelpLispinSeattle
« Reply #14 on: January 12, 2009, 04:30:33 PM »
Yeah!...I like both of them. Thank you very much "lambda king"....I bet yah
she did'nt say that yet.
