in making a plat of an access road, i am tying to make a line table based on labels assigned to a polyline.
first i connect all nodes with a polyline, then i selected Add Tag Labels under the Labels tab, and selected the poly line. Now the poly line has all the L1, L2, and so on labels.
Then under the Labels tab, i selected Add Table -->then Line Table. I choose where to put it and get a perfect line table, however under the bearings column instead of bearings i have gibberish.
i have checked all settings i can think of and still does not work...any ideas?? Thanks.
