Author Topic: Error is there a solution?  (Read 26918 times)
Re: Error is there a solution?
« Reply #15 on: January 09, 2009, 03:05:23 PM »
Ron when I ron the code you provided it's trigger the prompt alert with out finding the blocks even if the drawing is blank. Did I do something wrong?
;;NewClose command based off existing blocks
::Cadmoogle - 2009
(defun c:NewClose (/)
(command "-purge" "all" "" "N")
(defun manyblocknames2ss (blocklist / n out ss)
  (setq out (ssadd))
  (foreach name blocklist
    (setq n -1)
    (if (setq ss (ssget "_x" (list (cons 0 "INSERT") (cons 2 name))))
      (repeat (sslength ss)
        (ssadd (ssname ss (setq n (1+ n))) out)
  out
(manyblocknames2ss
   '("4FM_45BEND");
  (alert "** Warning ** Non-standard blocks found in drawing. Rename the blocks to the appropriate names and try again. This includes adding the numbers to fire hydrants and/or adding the as-built number to the prefix of the block(s) name. If this is a design drawing rename, the blocks to reflect a design not an as-built.")
 (exit)
);end 1st progn
  (setq blk (ssget "x" '((0 . "insert") (2 .
  "*WM_FIREHYD_,
   *WM_FIREHYD_1,
   *WM_FIREHYD_2,
   *WM_FIREHYD_3,
   *WM_FIREHYD_4,
   *WM_FIREHYD_5")
    (alert "Fire hydrants were located into the drawing that were not properly named, please correct and try again.")
  (exit)
);end 2nd progn
  (alert "All standard blocks found in drawing.... Now closing")
  (vla-sendcommand
  (vla-get-activedocument (vlax-get-acad-object))".close ")
 (princ))
You need to use the function like so if you're just checking the existence of any of the blocks.
(if (manyblocknames2ss '("4FM_45BEND"))
  (alert "\nYour computer are belong to us.")
  (alert "\nLooks good :)")
dustinthiesse
« Reply #16 on: January 09, 2009, 03:20:06 PM »
  "*WM_FIREHYD_,
   *WM_FIREHYD_1,
   *WM_FIREHYD_2,
   *WM_FIREHYD_3,
   *WM_FIREHYD_4,
   *WM_FIREHYD_5")
I think you need to use a strcat here...that long string is going to count new lines, tabs, and spaces...Try this
(setq blk(ssget "x" '((0 . "INSERT")(2 . (strcat
  "*WM_FIREHYD_,"
  "*WM_FIREHYD_1,"
  "*WM_FIREHYD_2,"
  "*WM_FIREHYD_3,"
  "*WM_FIREHYD_4,"
  "*WM_FIREHYD_5"))
Either that or use ronjon's function again!
(setq blk(manyblocknames2ss (setq hydr_blks(list "*WM_FIREHYD_"
  "*WM_FIREHYD_1"
  "*WM_FIREHYD_2"
  "*WM_FIREHYD_3"
  "*WM_FIREHYD_4"
  "*WM_FIREHYD_5"))))  ;;don't forget to take out the commas
cadmoogle
« Reply #17 on: January 09, 2009, 03:59:38 PM »
Command: ; error: bad SSGET list value
This is the result.
cadmoogle
« Reply #18 on: January 09, 2009, 04:08:19 PM »
Here's the file could some please look at it for me I'm about to bang my head on the wall.
Thank you
I'm getting the error listed above
::Cadmoogle - 2009
   "4FM_45BEND,"
   "18X2RE_TAP_SADDLE,"
   "20X2RE_TAP_SADDLE,"
   "RE_FLUSHHYD,"))
 (exit)
);end 1st progn
  "*WM_FIREHYD_,"
  "*WM_FIREHYD_1,"
  "*WM_FIREHYD_2,"
  "*WM_FIREHYD_3,"
  "*WM_FIREHYD_4,"
  "*WM_FIREHYD_5,"))
  (exit)
);end 2nd progn
  (vla-sendcommand
 (princ))
« Last Edit: January 09, 2009, 04:27:35 PM by cadmoogle »
dustinthiesse
« Reply #19 on: January 09, 2009, 04:36:59 PM »
  "*WM_FIREHYD_,"
  "*WM_FIREHYD_1,"
  "*WM_FIREHYD_2,"
  "*WM_FIREHYD_3,"
  "*WM_FIREHYD_4,"
  "*WM_FIREHYD_5"))
Sorry about that.  This seemed to work.
(setq blklist(strcat "4FM_45BEND,"
                     "RE_FLUSHHYD,"
(setq blk(ssget "x" (list(cons 0 "INSERT")(cons 2 blklist))))
(setq blklist2(strcat "*WM_FIREHYD_,"
                       "*WM_FIREHYD_1,"
                       "*WM_FIREHYD_2,"
                       "*WM_FIREHYD_3,"
                       "*WM_FIREHYD_4,"
                       "*WM_FIREHYD_5,"
  (setq blk(ssget "x" (list(cons 0 "INSERT")(cons 2 blklist2))))
  (progn ;;;etc....
cadmoogle
« Reply #20 on: January 09, 2009, 05:14:31 PM »
Okay I don't know what I've done.... it was working a one point and time but I've screwed something up.
Could someone please help me organize this?  :angel:
::Cadmoogle - 2009
                     "RE_FLUSHHYD,"
 (exit)
);end 1st progn
 (and
                       "*WM_FIREHYD_1,"
                       "*WM_FIREHYD_2,"
                       "*WM_FIREHYD_3,"
                       "*WM_FIREHYD_4,"
                       "*WM_FIREHYD_5,"
  (exit)
);end 2nd progn
  (vla-sendcommand
 (princ))
There is an extra right ) somewhere... and when I think I get it the command runs and does not find the blocks I'm going crazy I tell you.. 9 hours of this code and I'm ready to bang my head on the wall.
« Last Edit: January 09, 2009, 10:54:32 PM by cadmoogle »
« Reply #21 on: January 09, 2009, 05:23:18 PM »
Try this one...I used my subroutine  :-P
BTW...Are you using notepad to edit your code? If so, type vlide in the command line and paste your code into a new doc...it will help out tremendously with troubleshooting.
  (repeat 2
    (vla-purgeall
    (manyblocknames2ss
      '("4FM_45BEND"
"18X2RE_TAP_SADDLE"
"20X2RE_TAP_SADDLE"
"RE_FLUSHHYD"
       (alert
         If you have any questions please see <EDIT>"
       (exit)
  ) ;end 1st progn
'("*WM_FIREHYD_" "*WM_FIREHYD_1"
  "*WM_FIREHYD_2" "*WM_FIREHYD_3"
  "*WM_FIREHYD_4" "*WM_FIREHYD_5"
      (alert
      (exit)
    ) ;end 2nd progn
      (alert
      (vla-sendcommand
".close "
  (setq out (ssadd))
    (setq n -1)
  (if (zerop (sslength out))
    nil
    out
« Last Edit: January 10, 2009, 09:09:34 AM by CAB »
« Reply #22 on: January 09, 2009, 07:22:58 PM »
Here is the revised roitine, see notes. The last paren was missing.
;;  ::Cadmoogle - 2009  ; CAB error in this line, used colons & not semi-colons
(defun c:NewClose (/ blklist blklist2 blk)
  (setq blklist (strcat "4FM_45BEND,"
                        "RE_FLUSHHYD,"
  ;;  LOGIC:
  ;;  If test1 succeeds the alert and exit
  ;;  else If test2 succeeds alert & exit
  ;;  else send the CLOSE command
  (if (setq blk (ssget "x" (list (cons 0 "INSERT") (cons 2 blklist)))) ; test1
       (alert
         (strcat
           "** Warning ** Non-standard blocks found in drawing. "
           "Rename the blocks to the appropriate names and try again. "
           "This includes adding the numbers to fire hydrants and/or "
           "adding the as-built number to the prefix of the block(s) name. "
           "If this is a design drawing rename, the blocks to reflect a design not an as-built."
           "\nIf you have any questions please see <edit>"
       ; (exit) no need as this will exit
     )    ; end 1st progn
    ;;  no blklist so try another list of blocks
       (setq blklist2 (strcat "*WM_FIREHYD_," "*WM_FIREHYD_1," "*WM_FIREHYD_2," "*WM_FIREHYD_3,"
                              "*WM_FIREHYD_4," "*WM_FIREHYD_5,"
       (if (setq blk (ssget "x" (list (cons 0 "INSERT") (cons 2 blklist2)))) ; test2
            (alert
            (vla-sendcommand
              ".close "
       ) ; endif blklist2
     ) ; end 2nd progn
  (princ) ; moved to here
) ; CAB - this was missing
« Last Edit: January 10, 2009, 09:09:10 AM by CAB »
« Reply #23 on: January 09, 2009, 07:33:45 PM »
This is my variation. Not tested.  8-)
;; NewClose command based off existing blocks
;; Cadmoogle - 2009  ; CAB modified
(defun c:NewClose (/ blklist blk)
  (repeat 2
    (vla-purgeall (vla-get-activedocument (vlax-get-acad-object)))
  ;;  LOGIC:
    ((progn
       (setq blklist "4FM_45BEND,18X2RE_TAP_SADDLE,20X2RE_TAP_SADDLE,RE_FLUSHHYD")
     (alert
       (strcat
         "\nIf you have any questions please see <EDIT>"
    ((progn
       (setq blklist "*WM_FIREHYD_,*WM_FIREHYD_[1-5]")
     (alert
    (t
     (vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) ".close ")
« Last Edit: January 10, 2009, 09:10:29 AM by CAB »
cadmoogle
« Reply #24 on: January 09, 2009, 09:35:56 PM »
Thank you for the revisions and the new versions of the code. I was going crazy. I really should start using vlide. I'm so use to the notepad :P for quick edits. I was working really hard on this code today... I even isolated myself in my office :realmad:.
I can't wait for Monday!
cadmoogle
« Reply #25 on: January 09, 2009, 10:07:15 PM »
Now, once it's working what's the best way to make it run on close even if the 'X' is clicked, also is it possible to make it run only in drawings that existing in certain folders and any sub folders in the location?
X:\Eng\Gen\Asbuilts\*.dwg
but not select subfolders
X:\Eng\Gen\Asbuilts\Temp\*.dwg
I know you mentioned a reactor...but I have the slightest idea what I'm doing with those.
I followed your link from before and found some code posted here on the forums that I think could be modified. I would still like for the users to save their work, just not close without renaming the blocks. It would be nice if they 'End process' their AutoCAD it would generate an error email/text log save in a location without them knowing with the drawing data, but now I'm probably dreaming  :lmao: ...Can you send email through CAD?
Edit* The only thing I could find as now is a old command from CAB himself :P. It's got some writing to text file code in there.
http://www.theswamp.org/index.php?topic=3251.0
I also took out the email part. I found some code, but I do not wish to be that obvious with the command. I'm still not finding an existing code for trigger a text file with information. I could of swore I've seen one some time ago.... might had been just another request form a different member.
Looks like I need to do some more searching around.  8-)
(defun Save_Reactor_Create()
    (not clr:CloseReactor)
    (setq clr:CloseReactor
   (vlr-Editor-Reactor nil
     '((:vlr-beginSave  . PurgeBeforeClose))))
    ); end if
  ); end of Save_Reactor_Create
(Save_Reactor_Create)
(defun PurgeBeforeSave(reac args)
  (setq actDoc
(vla-get-ActiveDocument
  (repeat 3(vla-Purgeall actDoc))
  ); end of PurgeBeforeSave
Thank you again for the help,
Daniel
« Last Edit: January 09, 2009, 10:59:17 PM by cadmoogle »
cadmoogle
« Reply #26 on: January 09, 2009, 11:29:59 PM »
CAB, could you remove Priscilla's name for that post. I didn't mean to post that part. Also could you delete this post? It's just yours and ron's reply.
alanjt
  • Standby for witty remark...
« Reply #27 on: January 10, 2009, 01:13:39 AM »
    ); end if
  (setq actDoc
Daniel
this should work for your reactor needs:
(if (/= 'VLR-Command-Reactor (type ReactorCommandWillStart))
    (setq ReactorCommandWillStart
        (vlr-command-reactor nil
           '((:vlr-commandWillStart . CallbackCommandWillStart))
(defun CallbackCommandWillStart ( reactor cmdInfo / cmdName )
        (   (eq "QUIT" (setq cmdName (car cmdInfo)))
(c:NewClose)
Dropbox
cadmoogle
« Reply #28 on: January 10, 2009, 02:04:38 AM »
Thanks Alan, where do I place it? I've actually never worked with the reactors myself.
« Reply #29 on: January 10, 2009, 09:12:06 AM »
Done....
