(DEFUN C:xru ()
(command "-xref" "unload" (cdr (assoc 2 (ENTGET (CAR (ENTSEL "\N Select Element in XREF to UNLOAD "))))))
(DEFUN C:xrd ()
(command "-xref" "detach" (cdr (assoc 2 (ENTGET (CAR (ENTSEL "\N Select Element in XREF to DETACH "))))))
(DEFUN C:xre ()
(command "-xref" "reload" (cdr (assoc 2 (ENTGET (CAR (ENTSEL "\N Select Element in XREF to RELOAD "))))))
(DEFUN C:xrua () (command "-xref" "unload" "*"))
(DEFUN C:xrea () (command "-xref" "reload" "*"))
(DEFUN C:xrda () (command "-xref" "detach" "*"))
