Author Topic: Darray - another Dynamic tool !!  (Read 17831 times)
Andrea
Re: Darray - another Dynamic tool !!
« Reply #15 on: January 27, 2009, 12:46:49 PM »
yep,..
 :angel:
You can't imagine all the idea i have in my head..
the only restriction is the knowledge.
...and time.   :lol:
Keep smile...
Andrea
« Reply #16 on: January 28, 2009, 02:54:07 PM »
Thanks...
New Addition and modification....
Darray v. 1.5
RECTANGULAR option was replaced with LINEAR...
New RECTANGULAR options added.
- Allow Row and Column input
- Allow Entity rotation as polar or Rectangle Center by pressing SHIFT.
- New Mtext information for Rectangle option.
enjoy !
Keep smile...
M-dub
« Reply #17 on: January 28, 2009, 02:56:30 PM »
Again!
Great sutff, Andrea!
Andrea
« Reply #18 on: January 28, 2009, 10:44:34 PM »
Thanks !  :-)
Keep smile...
alisafei
« Reply #19 on: January 31, 2009, 07:52:04 AM »
hi, when i use the "darray" commanf after loading your lisp file, why not working..the command history like this one..
Command: darray
(L)inear/(R)ectangular/(P)olar/(A)rc ?: l
No unreferenced visual styles found.
Select objects: 1 found
Select objects:
Number of CopyArray: 5
Attach point...Regenerating model.  (WHY THIS ONE NEEDED?)
Base point...
Press (A)ngle/(Q)uantity : Deleting block "_{DarrayBlock}_".
1 block deleted.
no function definition: ACET-SYS-SHIFT-DOWN
i tried it in autocad2004 n 2009.
is the object must be a block or..?
Serge J. Gianolla
« Reply #20 on: January 31, 2009, 03:20:31 PM »
Ali, it is needing a function from ExpressTools. ET should be installed.
Andrea, j'espere que tu m'en veux pas de repondre a ta place  :oops:
Andrea
« Reply #21 on: January 31, 2009, 04:21:48 PM »
Base point...
This is where the selected entity is reffered absolutely needed..
ACET-SYS-SHIFT-DOWN function come with expresstools and is part of the acetutil4.fas file.
but you'r right. i'll modify the code to detect if some express function is available. thanks.
Serge...
très heureux d'avoir de tes nouvelles et que tu ai répondu.  ;-)
Keep smile...
alisafei
« Reply #22 on: January 31, 2009, 11:10:20 PM »
thanks for your reply.
i know the problem, i am using toolpac so i didn't installed "Express Tool" in my autocad.
can you modify it without expresstool?
Andrea
« Reply #23 on: February 01, 2009, 11:09:38 PM »
I would like to help....
but don't realy know how to use shift without using any arx or dvb file.
maybe in vbs ??  I need to check that..
or ...If some one have any idea..... :|
Keep smile...
Crank
« Reply #24 on: February 02, 2009, 02:13:05 AM »
Not in lisp, but I'm using the arx of Luis.
Gilles
« Reply #25 on: June 02, 2010, 12:56:22 PM »
Cool, Andrea.
Beautiful lisp.
I see a lot of aplications in what I do. cheesy
But one thing bothers me, I have not found how to impose a distance between objects created!
Is it possible and how should I do?
Thank you for your explanations.
Postscript: I am really no English
Aerdvark
« Reply #26 on: June 03, 2010, 03:06:27 PM »
Hi Andrea,
I can only say OMG  :lol:
Very nice program!
Aerdvark
Andrea
« Reply #27 on: June 04, 2010, 09:59:36 AM »
thanks Guys..
Gilles,..
j'vais ajouter ça à la prochaine version.
(it will be added on next release)
thanks.
Keep smile...
Gilles
« Reply #28 on: June 04, 2010, 12:51:49 PM »
Cool, je surveille......
