Author Topic: toolpalettes blocks not scaling correctly using annotative text & dims  (Read 1916 times)
alanjt
  • Standby for witty remark...
i recently switched to annotative text and dimensions, but now when i insert blocks from toolpalettes, if a block was set to insert with a scale of 1 and an auxiliary scale of "dimscale" it will not come in correctly because you can't change the dimscale to anything but 1.
what do i do? i can't have all my toolpalette blocks just come in at 1 scale
i'm using c3d 2009 btw.
Dropbox
Crank
Re: toolpalettes blocks not scaling correctly using annotative text & dims
« Reply #1 on: December 31, 2008, 11:34:07 AM »
Make the blocks you want to scale also annotative:
All you have to do is opening the wblock and change the variable ANNOTIVEDWG to 1. After that save the block again and after redefining the block it will use the annoscale.
alanjt
« Reply #2 on: December 31, 2008, 12:07:58 PM »
crank, that works great if each block is in an individual drawing and is just linework in it, but what if you just have 1 dwg with multiple blocks. i change the annotativedwg variable to 1, but it will not work.
is there a way around this, or do i need to just only use separate dwg for each block?
Dropbox
Crank
« Reply #3 on: December 31, 2008, 12:15:37 PM »
If all blocks are in one drawing, you must open each block with BEDIT.
Don't select anything! In the properties you can set annotative to yes.
Crank
« Reply #4 on: December 31, 2008, 12:19:25 PM »
[...] that works great if each block is in an individual drawing and is just linework in it[...]
You can also scale the text in a block if this text isn't annotative.
alanjt
« Reply #5 on: December 31, 2008, 12:27:45 PM »
beautiful!!!
thank you so much, now i just have to convert all the blocks.
thank you so much.
Dropbox
