Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
VB(A)
Topic:
Local variables (for each drawing)
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Local variables (for each drawing) (Read 2688 times)
simor
Guest
on:
December 30, 2008, 10:03:08 AM »
I'm trying to figure out if there is an easy way to have variables defined on a "per drawing" level. I thought that ThisDrawing will refer to the active drawing (in standalone project - not embedded) and so I will be able to use ThisDrawing.myvar and myvar defined under ThisDrawing as public but apparently once myvar is set under Drawing1.dwg I can see the same value when I'm working on Drawing2.dwg. (It's per project, not per dwg file).
I know I can use dictionaries but I thought that maybe there's some easier way, some keyword I can put next to the variable definition that will set the "per-file-scope".
uhmm am I clear?
Logged
Bryco
Water Moccasin
Re: Local variables (for each drawing)
Reply #1 on:
December 30, 2008, 10:28:18 AM »
Thisdrawing, like you have said, is merely the active drawing.
Perhaps the easiest way to achieve what you want is to come up with some rules that work for your project, if this drawing path comes from here, do this etc.
Logged
simor
Guest
Reply #2 on:
December 30, 2008, 02:13:41 PM »
Thanks Bryco. I was thinking of creating some array/table to store my per-dwg-data (new dwg = new record) but it's hard to believe autodesk/microsoft didn't prepare anything like that ... other than the dictionaries hmm. I'll have a closer look at them, maybe they aren't that scary - the implementation I have is really unclear
BTW, do you/anyone happen to know if this kind of variable scope is available when using ARX & .NET (C#)?
Logged
Bryco
Water Moccasin
Reply #3 on:
December 30, 2008, 02:24:59 PM »
Perhaps you could use the User setvars available as integer useri1, real userr1 or the string version. These are per drawing and may be all you need.
Net doesn't have anything magical for this that I know of.
Logged
Seagull
Have thousands of dwgs to process? Contact me.
WWW
Reply #4 on:
January 03, 2009, 12:08:41 PM »
Why not just write a wrapper for dictionaries that provides an easy / simplified interface? User vars are not the way to go imo.
Logged
cadanalyst@gmail.com
http://cadanalyst.slack.com
http://linkedin.com/in/cadanalyst
simor
Guest
Reply #5 on:
January 04, 2009, 08:33:44 AM »
I'm not a fan of the user vars either.. so I went the dictionary/xrecord direction and so far it's looking good. Thanks for the tips
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
VB(A)
Topic:
