Author Topic: (program) Compute proportionate distances  (Read 4233 times)
« on: October 04, 2004, 01:32:39 PM »
(defun c:proprt (/ p_block m_block lot)
  (princ "\nCompute proportionate distances based on Plat & Field measurments")
  (if (setq p_block (getreal "\nEnter platted block dimension: "))
    (if (setq m_block (getreal "\nEnter measured block dimension: "))
      (while (setq lot (getreal "\nEnter Lot dimension to proportion (<enter> to quit): "))
             ;; NOTE: '_pa' is global
             ;; this allows the us to use the computed distance
             ;; with native acad commands, like 'circle'
             ;; example
             ;; Command: circle
             ;; Specify center point for circle or [3P/2P/Ttr (tan tan radius)]:
             ;; Specify radius of circle or [Diameter] <49.9855>: !_pa
             ;; 49.9855
             (setq _pa (* (/ lot p_block) m_block))
             (princ (strcat "Proportionate dimension = " (rtos _pa)))
« Reply #1 on: October 04, 2004, 02:03:41 PM »
added some things, changed some things
;;; FUNCTION
;;; compute proportainate distances based on Plat & Field
;;; distances. Input can be either keyboard on picked points
;;; ARGUMENTS
;;; none
;;; USAGE
;;; proprt = just computes the distance
;;; proprtc = computes the distance and draws a circle from
;;;           selected point with a radius equal the computer
;;;           distance.
;;; PLATFORMS
;;; 2000+
;;; AUTHOR
;;; Copyright© 2004 Mark S. Thomas
;;; mark@theswamp.org
;;; VERSION
;;; 1.2 Mon Oct 04, 2004 14:00:24
  (if (setq p_block (getdist "\nPlatted block dimension: "))
    (if (setq m_block (getdist "\nMeasured block dimension: "))
      (while (setq lot (getreal "\nLot dimension to proportion (<enter> to quit): "))
             ;; example
             ;; Command: circle
             ;; 49.9855
(defun c:proprtc (/ p_block m_block lot _pa)
      (if (setq lot (getreal "\nLot dimension to proportion (<enter> to quit): "))
          (vl-cmdf "_circle" (getpoint "\nSpecify center point for circle: ") _pa)
« Reply #2 on: October 04, 2004, 02:17:08 PM »
Hi Mark, I believe with the inclusion of the vl-cmdf function you've made this 2000+ centric code. :wink:
« Reply #3 on: October 04, 2004, 02:18:33 PM »
dang it ........ you're right MP. Thanks.
« Reply #4 on: October 04, 2004, 03:01:05 PM »
added function to create AECC points based on computed distance and changed a couple of the prompts
;;; function
;;; compute proportionate distances based on plat & field
;;; distances. input can be either keyboard on picked points
;;; arguments
;;; none
;;; usage
;;; proprt = just computes the distance (r14+)
;;;           distance. (2000+)
;;; proprtp = computes and inserts an aecc point along the
;;;           selected bearing.(land desktop 2, 2i, 3, 4 and 2005)
;;; platforms
;;; r14+
;;; author
;;; copyright© 2004 mark s. thomas
;;; version
;;; 1.2 mon oct 04, 2004 14:00:24
;;; 1.3 mon oct 04, 2004 14:48:02
;;; todo:
;;; make sure user is running ldt before starting 'proprtp'
;;; write documentation
(defun mst-createcogopoint (pointcoords / aeccproject pnts newpoint)
  (vl-catch-all-apply
    (function
      (lambda ()
        (setq aeccproject
              (vlax-get-property
                (vla-getinterfaceobject
                  (vlax-get-acad-object) "aecc.application")
                'activeproject)
              ); setq
        (setq pnts
              (vlax-get-property
                aeccproject 'cogopoints)
              ); setq
        (setq
          count (vlax-get-property pnts 'count)
        (setq
          newpoint
          (vlax-invoke-method pnts 'add
                              (vlax-3d-point pointcoords) 1)
          ); setq
        (setq
          newpointnum (vlax-get-property newpoint 'number)
        ); lambda
      ); function
    ); vl-catch-all-apply
  ); defun
  (princ "\ncompute proportionate distances based on plat & field measurments")
  (if (setq p_block (getdist "\nplatted block dimension: "))
    (if (setq m_block (getdist "\nmeasured block dimension: "))
      (while (setq lot (getreal "\nplatted lot dimension to proportion (<enter> to quit): "))
             ;; note: '_pa' is global
             ;; example
             ;; command: circle
             ;; specify center point for circle or [3p/2p/ttr (tan tan radius)]:
             ;; specify radius of circle or [diameter] <49.9855>: !_pa
             ;; 49.9855
             (princ (strcat "proportionate dimension = " (rtos _pa)))
      (if (setq lot (getreal "\nplatted lot dimension to proportion (<enter> to quit): "))
          (vl-cmdf "_circle" (getpoint "\nspecify center point for circle: ") _pa)
(defun c:proprtp (/ p_block m_block lot start_pt dir _pa)
  (princ "\ncreate an aecc point using proportionate distances")
  (princ "based on plat & field measurments")
      (if (setq start_pt (getpoint "\nselect start point: "))
        (if (setq dir (angle start_pt (getpoint start_pt "\nselect point for direction: ")))
                 (mst-createcogopoint (polar start_pt dir _pa))
