Author Topic: Grading Out at Corners  (Read 1521 times)
dfarris75
« on: December 23, 2008, 03:42:48 PM »
How do you deal with grading outward at a 90 degree corner? When you grade out it wants to fillet the corner making it rounded which one does not always want.
George
Re: Grading Out at Corners
« Reply #1 on: December 23, 2008, 05:14:56 PM »
It's ugly, but I let the grading object do it's thing, then explode it by picking the OUTER feature line. This leaves me a feature line I can edit and remove the arc. Stretch, extend, etc to get a nice corner elevation.
Like I said, but I can get close enough for those few times it really irks someone enough to make me get rid of the arcs.
« Reply #2 on: December 23, 2008, 06:45:43 PM »
start and stop your grading regions just before the intersection.
!!caution should be used to NOT use the undo command after relocating the grading projection grips!!
dfarris75
« Reply #3 on: December 23, 2008, 10:19:39 PM »
I didn't know you could relocate the grips? What can you do with that?
I tried to stop at the corner and do two projections, but on the second one it behaved differently and asked for a distance of sorts...
« Reply #4 on: December 23, 2008, 10:41:59 PM »
the grading thought you overlapped and asked for a transition distance.....
moving the grips allows one to fine tune the gradings
