Author Topic: Who can write these codes in C#?  (Read 3837 times)
itcad
« on: December 20, 2008, 06:27:08 AM »
the codes:
// Includes
#define _AFX_NOFORCE_LIBS // we do not want to link to MFC DLLs or libs
#ifdef _DEBUG
#define WAS_DEBUG
#undef _DEBUG
#endif
#include "afxwin.h" // need this because rxmfcapi.h needs windows header.
#ifdef WAS_DEBUG
#undef WAS_DEBUG
#define _DEBUG
#endif
#include "aced.h"
#include "adslib.h"
#include "rxmfcapi.h"
// Standard C Test function
void mouse();           // ARX callbacks
void unmouse();           // ARX callbacks
BOOL filterMouse(MSG *pMsg);   // hook function for trace mouse wheel
// preventing from inserting the same hook twice.
static BOOL mouseDone = FALSE;
// Rx interface
void initApp()
acedRegCmds->addCommand( "Mwheel",     // Group name
                  "mwheel",     // Global function name
                  "mwheel",       // Local function name
                  ACRX_CMD_MODAL,   // Type
                  &mouse );       // Function pointer
                  "unmwheel",     // Global function name
                  "unmwheel",       // Local function name
                  &unmouse );       // Function pointer
acutPrintf( ".OK!\n" );
void unloadApp()
// Remove the command group because we are unloading
acedRegCmds->removeGroup( "Mwheel" );
// Removing all hooks
if (mouseDone == TRUE)
    acedRemoveFilterWinMsg(filterMouse);
// Entry point
extern "C" AcRx::AppRetCode acrxEntryPoint( AcRx::AppMsgCode msg, void* pkt)
switch( msg )
  case AcRx::kInitAppMsg:
    initApp();
    acrxUnlockApplication(pkt);
    acrxDynamicLinker->registerAppMDIAware(pkt);
    break;
  case AcRx::kUnloadAppMsg:
    unloadApp();
    break;
  default:
    break;
return AcRx::kRetOK;
  static long ptx=0;
  static long pty=0;
  static short zdt=0;
   struct resbuf rb;
  if (pMsg->message == WM_MOUSEWHEEL) //鼠标滚轮消息
    if (LOWORD(pMsg->wParam) == MK_CONTROL)
           return FALSE; // continue
       else
//        acutPrintf("Mouse Wheel!");
       zdt=(short)HIWORD(pMsg->wParam);
//        acutPrintf("%d\n",zdt);
       rb.restype = RTSHORT;
       rb.resval.rint = zdt;
       acedSetVar("USERI5", &rb);
    ptx = LOWORD(pMsg->lParam);
       if (zdt == 120)
      pty = HIWORD(pMsg->lParam)-1;
       if (zdt == -120)
      pty = HIWORD(pMsg->lParam)+1;
       SetCursorPos(ptx,pty);
       return TRUE; // continue
  if (pMsg->message == WM_MBUTTONDOWN) //鼠标中键按下消息
       rb.resval.rint = 100;
       acedSetVar("USERI4", &rb);
  if (pMsg->message == WM_MBUTTONUP) //鼠标中键抬起消息
       rb.resval.rint = 0;
void mouse()
  if (mouseDone == TRUE)   // already has the hook?
    return ;
  acutPrintf( "mouseing...\n" );
  if (acedRegisterFilterWinMsg(filterMouse) == FALSE)   //添加acadhook
    acutPrintf("Can't register Windows Msg hook - VH - mouse\n");
    return ;
  else
    mouseDone = TRUE;
       return ;
void unmouse()
    acedRemoveFilterWinMsg(filterMouse);   //卸载acadhook
    mouseDone = FALSE;
  if (mouseDone2 == TRUE)
    acedRemoveFilterWinMsg(filterMouse2);
    mouseDone2 = FALSE;
Draftek
Re: Who can write these codes in C#?
« Reply #1 on: December 21, 2008, 07:34:51 AM »
I can
Maverick®
« Reply #2 on: December 21, 2008, 06:26:42 PM »
 :lmao:
itcad
« Reply #3 on: December 21, 2008, 07:52:16 PM »
« Reply #4 on: December 21, 2008, 08:45:10 PM »
all your codes are belong to us
TonyT
« Reply #5 on: December 23, 2008, 09:35:27 AM »
I can
please write your codes.
http://www.caddzone.com/AcadWindowHook.cs
There's no support available for that sample code,
and I can't tell you if it will work in AutoCAD 2004.
uncoolperson
« Reply #6 on: December 23, 2008, 11:08:18 AM »
up-up-down-down-left-right-left-right-b-a-start
« Reply #7 on: December 23, 2008, 11:09:32 AM »
Greedy!  No love for the second player??
