Author Topic: Custom Linetypes and Scaling  (Read 2208 times)
dfarris75
« on: December 19, 2008, 02:12:19 PM »
Either my brain isn't working well today or the program doesn't compute linetypes how I'm thinking it does. I'm trying to get a linetype that would be +10',  -30' and repeating as such. I do the code as follows:
*SKIP_10X30,10'x30' SKIPLINE _  _  _  _  _  _  _  _  _
A,10,-30
and all is well if my drawing is set to a scale of 1 and the ltscale is set to 1. The lines measure proper. But of course when I change the scale of the drawing or the ltscale the distances are whack. Please wake me up to what's wrong with the code.
Re: Custom Linetypes and Scaling
« Reply #1 on: December 19, 2008, 02:50:02 PM »
A,10,-30
Technically your LTSCALE should always be set to 1 in MS any way, so what is the real question, and or how are you applying the line type scaling?
dfarris75
« Reply #2 on: December 19, 2008, 03:56:01 PM »
Yes I always set my ltscale to 1. This sprouted when I changed the drawing scale and the linetype changed along with it making the linetype incorrect in regard to the lengths.
« Reply #3 on: December 19, 2008, 04:01:01 PM »
I don't know I've just ran a couple of test here, and when I change the drawing scale with Drawing Settings my LTSCALE is unaffected.  So how or where are you changing yours that it does impact the ltscale?
dfarris75
« Reply #4 on: December 19, 2008, 04:12:58 PM »
Did you do a regen after changing the scale???
I went to Toolspace > Settings > Rt clicky dwg > Edit Drawing Settings > Units and Zone tab > Scale (in upper rt corner)
dfarris75
« Reply #5 on: December 19, 2008, 04:21:46 PM »
Weird it must be a dwg specific setting because it doesn't behave as such in another dwg.
dfarris75
« Reply #6 on: December 19, 2008, 04:23:46 PM »
Here see if you get the same result with this file.
« Reply #7 on: December 19, 2008, 04:48:48 PM »
I type LTSCALE and it was still set to 1, so I did not believe a regen would be in order....because LTSCALE was still set to 1 as before change to drawing scale...
The CULPRIT is your MSLTSCALE setting............. :evil:
« Last Edit: December 19, 2008, 04:53:52 PM by mjfarrell »
dfarris75
« Reply #8 on: December 19, 2008, 04:59:53 PM »
Man I was looking in the help file and didn't come across that one yet. I bashed my head against the wall a good while trying to figure it out. Thanks again!
CHulse
« Reply #9 on: December 19, 2008, 05:54:20 PM »
You beat me to it.
I've been bitten by that one too. I thought I was nuts...  :lol:
Cary Hulse
Urban Forestry Manager
Wetland Studies and Solutions
Civil 3D 2020 & 2023
« Reply #10 on: December 19, 2008, 07:25:54 PM »
Just an 'autocad' thing; but I don't know anything about that.  :wink:
dfarris75
« Reply #11 on: December 20, 2008, 10:08:37 AM »
You beat me to it.
Indeed, I thought I was losing my mind there. Glad that's over.
