Author Topic: H.O.S.E. problem  (Read 10864 times)
Re: H.O.S.E. problem
« Reply #30 on: December 19, 2008, 07:40:16 PM »
That didn't seem to work for me Ron, I think I used it right, within the command, but it did from outside of it.  Not sure if it's an '06 thing or not.  Here is what I have so far, and I might work on it some more, but I might just leave it.  It seems to keep the associativeness with polylines ( closed tested only ), but nothing else.  I have not found a way to have it not assualt the command line with ' Hatch boundary associativity removed. ', which can take up the whole history.  Oh well.
(defun c:DHE ( / *error* GetHatchNames Sel Ent EntData oData nStyle cScale BasePt HatchList Pos
    TogAngle tempList tempPt tempData MaxPos TogScale ScFac TogOrtho Ang45 Ang135 Ang225 Ang315 )
    ; Dynamic Hatch Edit.  Scale, rotation and pattern.
    (defun *error* ( msg )
        (vl-bt)
        (if oData (entmake oData))
        (if Ent (entdel Ent))
        (if msg (prompt (strcat "\n Error-> " msg)))
        (redraw)
    (defun GetHatchNames ( filePath / Opened tempStr tempPos tempName HatchList )
        (if (setq Opened (open filePath "r"))
            (while (setq tempStr (read-line Opened))
                    (and
                        (= (substr tempStr 1 1) "*")
                        (setq tempPos (vl-string-search "," tempStr))
                        (setq tempName (substr tempStr 2 (1- tempPos)))
                        (/= (strcase tempName) "SOLID")
                    (setq HatchList (cons tempName HatchList))
        (if Opened (close Opened))
        (reverse HatchList)
    (defun UpdateHatchReactor ( ent oHatEnt nHatEnt / EntData EndList StList )
        (setq EntData (entget ent))
        (if (member (cons 330 oHatEnt) EntData)
            (entmod (subst (cons 330 nHatEnt) (cons 330 oHatEnt) EntData))
                (setq EndList (member (assoc 5 EntData) EntData))
                (setq StList (reverse (member (car EndList) (reverse EntData))))
                (setq EndList (cdr EndList))
                (entmod
                    (append
                        StList
                        (append
                            (list
                                '(102 . "{ACAD_REACTORS")
                                (cons 330 nHatEnt)
                                '(102 . "}")
                            EndList
        (and
            (setq Sel (entsel "\n Select hatch to edit dynamicly: "))
            (setq oData (entget (car Sel)))
            (= (cdr (assoc 0 oData)) "HATCH")
            (setq nStyle (cdr (assoc 2 oData)))
            (setq cScale (cdr (assoc 41 oData)))
            (setq BasePt (cadr Sel))
            (setq HatchList
                (GetHatchNames
                    (if (zerop (getvar 'Measurement))
                        (findfile "acad.pat")
                        (findfile "acadiso.pat")
            (setq MaxPos (1- (length HatchList)))
            (setq Pos (vl-position nStyle HatchList))
            (setq TogScale 1)
            (setq TogAngle 0)
            (setq ScFac 1.)
            (setq TogOrtho (getvar 'OrthoMode))
            (setq Ang45 (* pi 0.25))
            (setq Ang135 (* pi 0.75))
            (setq Ang225 (* pi 1.25))
            (setq Ang315 (* pi 1.75))
            (while
                (and
                    (princ
                        (strcat
                            "\r pattern: "
                            nStyle
                            " [Forward / Reverse], change Angle: "
                            (if (zerop TogAngle) "No" "Yes")
                            " , change Scale: "
                            (if (zerop TogScale) "No" "Yes")
                            " , sCale factor: "
                            (rtos ScFac 2 4)
                    (setq tempList (grread T 11))
                    (not (equal (car tempList) 3))
                (or
                    Ent
                    (setq Ent (car Sel))
                (setq EntData (entget Ent '("*")))
                    ( (equal (car tempList) 5)
                        (setq tempPt (cadr tempList))
                        (setq tempAng (angle BasePt tempPt))
                        (setq tempAng
                            (if (zerop TogOrtho)
                                tempAng
                                        (or
                                            (<= tempAng Ang45)
                                            (>= tempAng Ang315)
                                        0.0
                                    ( (<= Ang45 tempAng Ang135)
                                        (* pi 0.5)
                                    ( (<= Ang135 tempAng Ang225)
                                        pi
                                    ( (<= Ang225 tempAng Ang315)
                                        (* pi 1.5)
                        (setq tempPt (polar BasePt tempAng (distance BasePt tempPt)))
                        (if (not (zerop (distance tempPt BasePt))) ; <- Thanks to Alan ( CAB )
                                (redraw)
                                    (or
                                        (equal TogScale 1)
                                        (equal TogAngle 1)
                                    (grdraw BasePt tempPt 1 1)
                                (setq tempData EntData)
                                (if (equal TogScale 1)
                                    (setq tempData
                                        (subst
                                            (cons
                                                41
                                                (* (distance tempPt BasePt) cScale ScFac)
                                            (assoc 41 tempData)
                                            tempData
                                (if (equal TogAngle 1)
                                    (setq tempData
                                        (subst
                                            (cons 52 tempAng)
                                            (assoc 52 tempData)
                                            tempData
                                (if (entmake tempData)
                                        (entdel Ent)
                                        (setq Ent (entlast))
                    ((equal (car tempList) 2)
                            ( (member (cadr tempList) '(40 102)) ; F pushed
                                (if (equal Pos MaxPos)
                                    (setq Pos -1)
                                (setq nStyle (nth (setq Pos (1+ Pos)) HatchList))
                                (if (entmake
                                        (subst
                                            (cons 2 nStyle)
                                            (assoc 2 EntData)
                                            EntData
                                        (entdel Ent)
                            ( (member (cadr tempList) '(82 114)) ; R pushed
                                (if (zerop Pos)
                                    (setq Pos (1+ MaxPos))
                                (setq nStyle (nth (setq Pos (1- Pos)) HatchList))
                                (if (entmake
                                        (subst
                                            (cons 2 nStyle)
                                            (assoc 2 EntData)
                                            EntData
                                        (entdel Ent)
                            ( (member (cadr tempList) '(65 97)) ; A pushed
                                (setq TogAngle (abs (1- TogAngle)))
                            ( (member (cadr tempList) '(83 115)) ; S pushed
                                (setq TogScale (abs (1- TogScale)))
                            ( (member (cadr tempList) '(67 99)) ; C pushed
                                (setq ScFac
                                        ( (getreal (strcat "\n Enter scale factor <" (rtos ScFac 2 4) ">: ")) )
                                        (t ScFac)
                                    (entmake
                                        (subst
                                            (cons
                                                41
                                            (assoc 41 EntData)
                                            EntData
                                        (entdel Ent)
                            ( (equal (cadr tempList) 15) ; F8 pushed
                                (setvar 'OrthoMode (setq TogOrtho (abs (1- TogOrtho))))
            (foreach i (cdr (member '(100 . "AcDbHatch") (entget Ent)))
                (if (equal (type (cdr i)) 'ENAME)
                    (UpdateHatchReactor (cdr i) (cdr (assoc -1 oData)) Ent)
                    ;(setq EntList (cons (cdr i) EntList))
            (if EntList
                (vlax-invoke (vlax-ename->vla-object Ent) 'AppendOuterLoop (apply 'vlax-ename->vla-object EntList))
            (setq EntList nil)|;
    (redraw)
« Reply #31 on: December 21, 2008, 07:14:01 PM »
Worked well here Tim with ACAD2000 & no message 'Hatch boundary associativity removed'
Andrea
« Reply #32 on: December 21, 2008, 10:16:52 PM »
tested on 2009..
Keep smile...
Andrea
« Reply #33 on: December 21, 2008, 10:21:09 PM »
tested on 2009 with CMDECHO set to 0..
Keep smile...
Andrea
« Reply #34 on: December 21, 2008, 11:19:43 PM »
For comment..
I've made some test on 2009.
- Rotation do also a scale..
- Rotation do not alway follow the hatch pattern
- Scale do also a rotation.
- ORTHO work only 0 90 180 180 and do not follow the SNAPANG variable.
don't know if it is the same on older release..
Keep smile...
« Reply #35 on: December 22, 2008, 11:05:09 AM »
Thanks for testing Alan.  Good to hear it works there.
Andrea,
  I thought about following the SnapAng variable, but didn't do it just because I don't change it very often.  That shouldn't get a change too hard to make though.  I'll see about adding it.
« Reply #36 on: December 22, 2008, 11:18:13 AM »
For comment..
FWIW...Tim I do not see any of these issues in 09 everything appears to work fine. The only drawback is the non-assoc hatch created with objects other that a polyline.
Ron
[/quote]
« Reply #37 on: December 22, 2008, 12:14:31 PM »
Thanks Ron.
