I do see the message now. I didn't know that they first tests I was doing was on non-associated hatches. I will see if I can figure out how to keep them associated if they are. Here is a new version that has the ortho honored, and a new prompt. It will let you go forward or backward in the hatch patter list. Options are now as followed; f = forward pattern, r = back ( reverse ) pattern, a = angle, s = scale, c = scale factor
(defun c:DHE ( / *error* GetHatchNames Sel Ent EntData oData nStyle cScale BasePt HatchList Pos
TogAngle tempList tempPt tempData MaxPos TogScale ScFac TogOrtho Ang45 Ang135 Ang225 Ang315 )
; Dynamic Hatch Edit. Scale, rotation and pattern.
(defun *error* ( msg )
(vl-bt)
(if oData (entmake oData))
(if Ent (entdel Ent))
(if msg (prompt (strcat "\n Error-> " msg)))
(redraw)
(defun GetHatchNames ( filePath / Opened tempStr tempPos tempName HatchList )
(if (setq Opened (open filePath "r"))
(while (setq tempStr (read-line Opened))
(and
(= (substr tempStr 1 1) "*")
(setq tempPos (vl-string-search "," tempStr))
(setq tempName (substr tempStr 2 (1- tempPos)))
(/= (strcase tempName) "SOLID")
(setq HatchList (cons tempName HatchList))
(if Opened (close Opened))
(reverse HatchList)
(and
(setq Sel (entsel "\n Select hatch to edit dynamicly: "))
(setq oData (entget (car Sel)))
(= (cdr (assoc 0 oData)) "HATCH")
(setq nStyle (cdr (assoc 2 oData)))
(setq cScale (cdr (assoc 41 oData)))
(setq BasePt (cadr Sel))
(setq HatchList
(GetHatchNames
(if (zerop (getvar 'Measurement))
(findfile "acad.pat")
(findfile "acadiso.pat")
(setq MaxPos (1- (length HatchList)))
(setq Pos (vl-position nStyle HatchList))
(setq TogScale 1)
(setq TogAngle 0)
(setq ScFac 1.)
(setq TogOrtho (getvar 'OrthoMode))
(setq Ang45 (* pi 0.25))
(setq Ang135 (* pi 0.75))
(setq Ang225 (* pi 1.25))
(setq Ang315 (* pi 1.75))
(while
(and
(princ
(strcat
"\r pattern: "
nStyle
" [Forward / Reverse], change Angle: "
(if (zerop TogAngle) "No" "Yes")
" , change Scale: "
(if (zerop TogScale) "No" "Yes")
" , sCale factor: "
(rtos ScFac 2 4)
(setq tempList (grread T 11))
(not (equal (car tempList) 3))
(or
Ent
(setq Ent (car Sel))
(setq EntData (entget Ent '("*")))
( (equal (car tempList) 5)
(setq tempPt (cadr tempList))
(setq tempAng (angle BasePt tempPt))
(setq tempAng
(if (zerop TogOrtho)
tempAng
(or
(<= tempAng Ang45)
(>= tempAng Ang315)
0.0
( (<= Ang45 tempAng Ang135)
(* pi 0.5)
( (<= Ang135 tempAng Ang225)
pi
( (<= Ang225 tempAng Ang315)
(* pi 1.5)
(setq tempPt (polar BasePt tempAng (distance BasePt tempPt)))
(if (not (zerop (distance tempPt BasePt))) ; <- Thanks to Alan ( CAB )
(redraw)
(or
(equal TogScale 1)
(equal TogAngle 1)
(grdraw BasePt tempPt 1 1)
(setq tempData EntData)
(if (equal TogScale 1)
(setq tempData
(subst
(cons
41
(* (distance tempPt BasePt) cScale ScFac)
(assoc 41 tempData)
tempData
(if (equal TogAngle 1)
(setq tempData
(subst
(cons 52 tempAng)
(assoc 52 tempData)
tempData
(if (entmake tempData)
(entdel Ent)
(setq Ent (entlast))
((equal (car tempList) 2)
( (member (cadr tempList) '(40 102)) ; F pushed
(if (equal Pos MaxPos)
(setq Pos -1)
(setq nStyle (nth (setq Pos (1+ Pos)) HatchList))
(if (entmake
(subst
(cons 2 nStyle)
(assoc 2 EntData)
EntData
(entdel Ent)
( (member (cadr tempList) '(82 114)) ; R pushed
(if (zerop Pos)
(setq Pos (1+ MaxPos))
(setq nStyle (nth (setq Pos (1- Pos)) HatchList))
(if (entmake
(subst
(cons 2 nStyle)
(assoc 2 EntData)
EntData
(entdel Ent)
( (member (cadr tempList) '(65 97)) ; A pushed
(setq TogAngle (abs (1- TogAngle)))
( (member (cadr tempList) '(83 115)) ; S pushed
(setq TogScale (abs (1- TogScale)))
( (member (cadr tempList) '(67 99)) ; C pushed
(setq ScFac
( (getreal (strcat "\n Enter scale factor <" (rtos ScFac 2 4) ">: ")) )
(t ScFac)
(entmake
(subst
(cons
41
(assoc 41 EntData)
EntData
(entdel Ent)
( (equal (cadr tempList) 15) ; F8 pushed
(setvar 'OrthoMode (setq TogOrtho (abs (1- TogOrtho))))
(redraw)
