When you delete an object with Extended Entity Data (xdata), a regapp ID remains in the application ID (APPID) symbol table. When a file contains excess unreferenced regapp IDs, performance and file size may be negatively affected.
ARX[/b] from c:\program files\ to c:\program files (x86)\ = Same results.Then I copied the TotalPurge from c:\program files (x86)\ to c:\program files\ = different results, it seem to be purging but no dialog and it crashed autocad with Unhandled Exception. See belowQuoteApplication does not support just-in-time (JIT)debugging. See the end of this message for details.************** Exception Text **************Autodesk.AutoCAD.Runtime.Exception: eWasErased...
Oh one other thing. When you are deleting xdata are you also deleting theRregapp IDs too?QuoteWhen you delete an object with Extended Entity Data (xdata), a regapp ID remains in the application ID (APPID) symbol table. When a file contains excess unreferenced regapp IDs, performance and file size may be negatively affected.
Quote from: Krushert on January 24, 2011, 01:44:42 PMOh one other thing. When you are deleting xdata are you also deleting theRregapp IDs too?QuoteWhen you delete an object with Extended Entity Data (xdata), a regapp ID remains in the application ID (APPID) symbol table. When a file contains excess unreferenced regapp IDs, performance and file size may be negatively affected. yes....but to be honnest, I need to make more test with this.mabe you can help me test this ?Thanks.
dhatch doesn't work in autocad 2004
Quote from: Brick_top on January 21, 2011, 05:50:09 AMdhatch doesn't work in autocad 2004 Andrea,Those of us living in the dark ages (2005) would still like to be able to use this wonderful program.Moderator,Perhaps the TotalPurge could be another thread.bayoubuoy
