Author Topic: Dhatch. New Way to Hatch !  (Read 44955 times)
Andrea
Re: Dhatch. New Way to Hatch !
« Reply #75 on: January 21, 2011, 12:53:09 PM »
ok krusher..
I've installed the program on my laptop and seem to work well
could you help me to resove this problem ?
1) whats happen when you run this (TPreadconfig)
2) what'S happen when you run TPconfig ?
Keep smile...
Krushert
  • FREE BEER Tomorrow!!
« Reply #76 on: January 21, 2011, 01:10:31 PM »
ok krusher..
Sure
Results from TPreadconfig
Command: TPreadconfig
Unknown command "TPREADCONFIG".  Press F1 for help.
Command:
From TPconfig
Command: TPCONFIG
nil
Command:
Andrea
« Reply #77 on: January 21, 2011, 01:41:14 PM »
ok krusher..
Sure
Command:
You need to run the command with the accolade symbole (...)
eg:
command:(TPreadconfig)
From TPconfig
Command: TPCONFIG
nil
Command:
ok...no dialog appear ?
also,...are you local administrator ?
« Last Edit: January 21, 2011, 01:52:17 PM by Andrea »
Keep smile...
Krushert
« Reply #78 on: January 21, 2011, 02:00:22 PM »
ok krusher..
Sure
Command:
eg:
command:(TPconfig)
Okay with this I get the Error Dialog with the Message ConfigFile is missing.
Command: (TPREADCONFIG)
nil
From TPconfig
Command: TPCONFIG
nil
Command:
Got no dialog with this
Command: (TPCONFIG)
*Cancel*
no function definition: TPCONFIG
Nope no dialog with calling it with () or not
yes.  For giggles I even added the path to the folder in "Options>Files>Support"
Andrea
« Reply #79 on: January 21, 2011, 02:11:51 PM »
ok..
if you run command:(TPREADCONFIG)
you got "Config file is missing" error right ?
if you run command:TPCONFIG
no dialog appear ?
if that correct...the problem is in reading the cfg file.
do you have 32 or 64 bits station ?
is the installation are in c:\program files   or   c:\program files (x86)  ??
thanks for the help.
anyone else have same problem ?
Keep smile...
Krushert
« Reply #80 on: January 21, 2011, 02:26:30 PM »
See below,
ok..
you got "Config file is missing" error right ? Correct
no dialog appear ? Correct
Andrea
« Reply #81 on: January 21, 2011, 03:24:04 PM »
ok...
copy all files in c:\program files\Ductisoft\TotalPurge
and see what it is happen...
I think the installation creation did something strange...
unfortunately I do not have access to my 64bits computer at this moment.
last test...could you give me what you get with this code ?
(getenv "programfiles")
thanks.
« Last Edit: January 21, 2011, 08:20:44 PM by Andrea »
Keep smile...
xiaxiang
« Reply #82 on: January 23, 2011, 03:39:25 AM »
I've totaly remake the Megapurge program.
It call TotalPurge and it is Totally Free.
Enjoy !
Thanks for sharing! :-) :-) :-)
xyp1964
« Reply #83 on: January 23, 2011, 10:06:42 PM »
hatch rotate
Krushert
« Reply #84 on: January 24, 2011, 07:25:58 AM »
ok...
thanks.
Will do after my site visit this morning.  So look for something this afternoon.  Thanks for help.
Krushert
« Reply #85 on: January 24, 2011, 11:14:23 AM »
Copy the files to c:\program files\ from c:\program files (x86)\ or vice versa?
I will go play trial and error.
The result.
"C:\\Program Files"
Krushert
« Reply #86 on: January 24, 2011, 11:41:19 AM »
Okay I copied the folder ObjectDCL ARX from c:\program files\ to c:\program files (x86)\ = Same results.
Then I copied the TotalPurge from c:\program files (x86)\ to c:\program files\ =  different results, it seem to be purging but no dialog and it crashed autocad with Unhandled Exception.  See below
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
Autodesk.AutoCAD.Runtime.Exception: eWasErased
   at Autodesk.AutoCAD.DatabaseServices.ObjectId.Open(OpenMode mode, Boolean openErased, Boolean forceOpenOnLockedLayer)
   at Autodesk.AutoCAD.LayerManager.LayerManagerControl.GetAlternativeDescription(LayerRecord lr)
   at Autodesk.AutoCAD.LayerManager.LayerRecord.get_Description()
   at Autodesk.AutoCAD.LayerManager.LayerManagerControl.Application_Idle(Object sender, EventArgs e)
   at System.EventHandler.Invoke(Object sender, EventArgs e)
   at Autodesk.AutoCAD.ApplicationServices.Application.raise_Idle(Object value0, EventArgs value1)
   at Autodesk.AutoCAD.ApplicationServices.Application.OnIdle()
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4952 (win7RTMGDR.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
acdbmgd
    Assembly Version: 18.0.0.0
    Win32 Version: 18.0.309.0.0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/AcdbMgd.DLL
System
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
msvcm90
    Assembly Version: 9.0.30729.4926
    Win32 Version: 9.00.30729.4926
    CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_08e1a05ba83fe554/msvcm90.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
PresentationFramework
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.6920.5001 built by: Win7RTMGDR
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
    CodeBase: file:///C:/Windows/assembly/GAC_64/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
AdWindowsInterop
    Assembly Version: 0.0.0.0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/AdWindowsInterop.DLL
AdWindows
    Assembly Version: 2.1.0.0
    Win32 Version: 2.1.123.309
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/AdWindows.DLL
acmgd
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/acmgd.DLL
System.Core
    Assembly Version: 3.5.0.0
    Win32 Version: 3.5.30729.4926 built by: NetFXw7
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AcWindows
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/AcWindows.DLL
AcWindows.resources
    Win32 Version: 18.0.55.0.0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/en-US/AcWindows.resources.DLL
AcCui
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/AcCui.DLL
AecMgdReverse
    Assembly Version: 6.0.82.0
    Win32 Version: 6, 0, 82, 0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/AecMgdReverse.DLL
AecRibbon
    Win32 Version: 6.0.82.0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/AecRibbon.DLL
AecSpaceOffsetRulesManager
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/AecSpaceOffsetRulesManager.DLL
AecSpaceOffsetStandardBasic
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/AecSpaceOffsetStandardBasic.DLL
AecBaseMgd
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/AecBaseMgd.DLL
AecSpaceOffsetStandardBasic.resources
    Assembly Version: 6.0.56.0
    Win32 Version: 6.0.56.0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/en-US/AecSpaceOffsetStandardBasic.resources.DLL
AecArchMgd
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/AecArchMgd.DLL
AecSpaceOffsetStandardBOMA
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/Space%20Calculation%20Standards/AecSpaceOffsetStandardBOMA.dll
AecSpaceOffsetStandardBOMA.resources
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/en-US/AecSpaceOffsetStandardBOMA.resources.DLL
AecSpaceOffsetStandardDIN
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/Space%20Calculation%20Standards/AecSpaceOffsetStandardDIN.dll
AecSpaceOffsetStandardDIN.resources
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/en-US/AecSpaceOffsetStandardDIN.resources.DLL
AecSpaceOffsetStandardSIS
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/Space%20Calculation%20Standards/AecSpaceOffsetStandardSIS.dll
AecSpaceOffsetStandardSIS.resources
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/en-US/AecSpaceOffsetStandardSIS.resources.DLL
BzLocation
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/BzLocation.DLL
PROJECTPOINTCLIENTLib
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/PROJECTPOINTCLIENTLib.DLL
AcadObjectRegister32_2010
    Win32 Version: 0.0.0.0
    CodeBase: file:///C:/Users/Ted%20Krush/AppData/Local/Microsoft/Windows%20Sidebar/Gadgets/MonitorV1.0.0.1.gadget/dll/AcadObjectRegister32_2010.dll
AcadObjectRegister64_2010
    CodeBase: file:///C:/Users/Ted%20Krush/AppData/Local/Microsoft/Windows%20Sidebar/Gadgets/MonitorV1.0.0.1.gadget/dll/AcadObjectRegister64_2010.dll
Interop.RepositoryServerLib
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Users/Ted%20Krush/AppData/Local/Microsoft/Windows%20Sidebar/Gadgets/MonitorV1.0.0.1.gadget/dll/Interop.RepositoryServerLib.DLL
AcLayer
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/AcLayer.DLL
System.Windows.Forms
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
AcLayer.resources
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/en-US/AcLayer.resources.DLL
AecLayerManagerEx
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/AecLayerManagerEx.DLL
Accessibility
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
AecLayerManagerEx.resources
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/en-US/AecLayerManagerEx.resources.DLL
AecDtlDb
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/AecDtlDb.DLL
AecDtlDbUI
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/AecDtlDbUI.DLL
AecDtlDbLib
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/AecDtlDbLib.DLL
ContextualTabSelectorRules
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/AcWindows.dll
PresentationFramework.Aero
    Win32 Version: 3.0.6920.4902 built by: NetFXw7
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
ManagedMC3
    Assembly Version: 2.20.0.0
    Win32 Version: 3.14.1
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/ManagedMC3.DLL
AcXrefUtil
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/AcXrefUtil.DLL
AecUiWindows
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/AecUiWindows.DLL
AecUiWindows.resources
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/en-US/AecUiWindows.resources.DLL
AecRibbon.resources
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202010/en-US/AecRibbon.resources.DLL
7_waf3hd
System.Web.Services
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
qd8tc42g
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
Krushert
« Reply #87 on: January 24, 2011, 11:47:16 AM »
I also got this at the command line when I appload the total purge. But again no dialog.
Command:
TotalPurge 2.0 By DuctiSoft inc. Loading ObjectDCL ARX... done.
ObjectDCL is not registered and will work only for selected applications.
Please visit http://www.objectdcl.com/ to learn about what more ObjectDCL
technology can do for you.
Command:
Andrea
« Reply #88 on: January 24, 2011, 12:24:25 PM »
Command:
Command:
Thank you Krusher..
Ok,...for the error you have...it seem that is isn't the Routine.
Do you use more than simple AutoCAD vanilla ?
To have acces to the dialogbox you need to use "TPconfig" command.
Please take 2 min. to read the help file.  ^-^
For some reason..on some 64bits machine...the (getenv "programfiles") return "c:\Program files (x86)" and sometime "c:\program files" I've never undertood that....but thanks. I'll fix that on next release.
the ..".....ObjectDCL is not registered..." message mean that the ObjectDCL software it is not registred, but it never mind because it still working on signed project.
Thanks again for all your help and taking time to test and use my program.
it's like people like you that I can continue to learn and improve my knowledge.
Andrea.
Keep smile...
Krushert
« Reply #89 on: January 24, 2011, 01:39:45 PM »
  No I am running Autocad Architecture 2010.
Okay I see it now.  for some reason I was expecting a dialog to pop up at the command call.  But this way is better.  My preferred way anyway.
  I actually get this error from time to time.  Autocad is ruining but I can do nothing because will not continue.  Very frustrating
Okay.
Thank you Krusher..
Andrea.
No problem.  Anytime!
