Author Topic: Dhatch. New Way to Hatch !  (Read 44845 times)
New Shooz
Re: H.O.S. New Way to Hatch !
« Reply #15 on: December 17, 2008, 04:19:34 PM »
Looks very cool :)
Sebb77
« Reply #16 on: December 17, 2008, 04:22:02 PM »
Great routine ! Thanks a lot for sharing again, you have no idea how useful it will be here! :-)
Andrea we are already using a couple of your routine in our offices. You're about to become a living legend in here  :angel:
I 'll try to add a key that would update the hatch angle... not figured out yet...
Andrea
« Reply #17 on: December 17, 2008, 04:45:29 PM »
Rotation DONE !  8-)
thanks all.
Keep smile...
jonesy
  • SuperMod
« Reply #18 on: December 17, 2008, 04:48:11 PM »
Wow. This looks like a great addition to the toolbox
Thanks for posting it!
« Reply #19 on: December 17, 2008, 05:04:23 PM »
Great functionality Andrea.
Serge J. Gianolla
« Reply #20 on: December 17, 2008, 05:10:58 PM »
Rotation DONE !  8-)
thanks all.
Mon vieux tu m'epates.  8-) Mais cela m'etonne pas tu es deja en 2009 [lisp header] :lmao: Well done
« Last Edit: December 17, 2008, 05:18:37 PM by Serge J. Gianolla »
Spike Wilbury
« Reply #21 on: December 17, 2008, 05:15:56 PM »
When I grow up, I would like to do that kind of routines... (all the stuff you can do with autolisp - David Betz did a great base work)
Nice !
« Reply #22 on: December 17, 2008, 05:30:57 PM »
Andrea,
If you add 135 degrees to your rotation angle, then the rotation will match the angle on the screen.
(setq rangle (+ (angle (cadr input) centerpoint) (angtof "135")))
Andrea
« Reply #23 on: December 17, 2008, 06:23:50 PM »
thanks all...
nice catch Ronjonp
i've updated my routine.. thanks.   :roll:
Keep smile...
Andrea
H.O.S. release 2 New Way to Hatch !
« Reply #24 on: December 18, 2008, 05:17:20 PM »
H.O.S. rel. 2
changes:
- allow to use F8 to toggle the ORTHOMODE.
- you can now continue to switch Hatch Pattern during the rotation step.
- allow to use the key 1 to 9 to switch the 9 basic autoCAD color in real time.
Next challenge...
  - change the Origin in real time...
 :whistle:
Keep smile...
GDF
« Reply #25 on: December 18, 2008, 05:40:07 PM »
Very nice, the routine Andrea. Works great.
Andrea
« Reply #26 on: December 18, 2008, 10:18:39 PM »
HOS changed for Dhatch (Dynamic HATCH)
I think is more appropriate now with all modifications....and follow the DHE from Mr. Willey ;-)
there it is..
New Release Dhatch 2.1
I have made some fix.
« Last Edit: December 18, 2008, 10:21:55 PM by Andrea »
Keep smile...
M-dub
Re: Dhatch. New Way to Hatch !
« Reply #27 on: December 19, 2008, 08:47:19 AM »
Dhatch is a better name for it.  :)
« Reply #28 on: December 19, 2008, 08:48:13 AM »
yea, now it sounds french  :lol:
M-dub
« Reply #29 on: December 19, 2008, 08:50:36 AM »
lol!
Yeah, but Dynamic Hatch is exactly what this utility is!
French... touché :)
