Author Topic: Dhatch. New Way to Hatch !  (Read 44852 times)
Krushert
  • FREE BEER Tomorrow!!
LE3
Re: Dhatch. New Way to Hatch !
« Reply #91 on: January 24, 2011, 02:21:13 PM »
Just noted this...
The error below it is from an assembly - from one of the .NET programs that are running - if that's the case make a debug into your code...
See if helps.
ARX[/b] from c:\program files\ to c:\program files (x86)\ = Same results.
Then I copied the TotalPurge from c:\program files (x86)\ to c:\program files\ =  different results, it seem to be purging but no dialog and it crashed autocad with Unhandled Exception.  See below
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
Autodesk.AutoCAD.Runtime.Exception: eWasErased
Andrea
« Reply #92 on: January 24, 2011, 07:53:45 PM »
Oh one other thing.
When you are deleting xdata are you also deleting theRregapp IDs too?
When you delete an object with Extended Entity Data (xdata), a regapp ID remains in the application ID (APPID) symbol table. When a file contains excess unreferenced regapp IDs, performance and file size may be negatively affected.
yes....but to be honnest, I need to make more test with this.
mabe you can help me test this ?
Thanks.
Keep smile...
Krushert
« Reply #93 on: January 25, 2011, 07:33:25 AM »
bayoubuoy
« Reply #94 on: January 25, 2011, 09:59:34 AM »
dhatch doesn't work in autocad 2004  :cry:
Andrea,
Those of us living in the dark ages (2005) would still like to be able to use this wonderful program.
Moderator,
Perhaps the TotalPurge could be another thread.
bayoubuoy
Andrea
« Reply #95 on: January 25, 2011, 10:36:20 AM »
Andrea,
Moderator,
bayoubuoy
Tanks Bayou...
New Thread TotalPurge was started.
Keep smile...
