Author Topic: Dhatch. New Way to Hatch !  (Read 44902 times)
Andrea
Re: Dhatch. New Way to Hatch !
« Reply #60 on: January 22, 2009, 05:06:38 PM »
you'r right..
File updated...sorry all. :oops:
Keep smile...
GDF
« Reply #61 on: January 23, 2009, 10:19:33 AM »
A great tool now, thanks for sharing it. I really like the way it works. Very dynamic.
So what's next...always looking forward to what you come up with .
xiaxiang
« Reply #62 on: December 30, 2010, 09:06:42 PM »
In our office...we use several client and add'on programs..
some of these put many scrap on  drawings..
All user run my MEGAPURGE program when saving.
allowing user to reduce filesize and remove all un-needed scrap.
it contain all AutoCAD purge and Audit function and extra cleaning
all The options are saved in our network drive in a specific user configuration.
that allow us to change PC without doing anything.
Since MEGAPURE is instored in all offices, user saw 90% more effiencienty, and some times reduce file over 70%.
some of our department work with DWG file over 90MB AFTER MEGAPURGE it.
MEGAPURGE is awesome,Andrea ,can you post it for me?
Andrea
« Reply #63 on: January 20, 2011, 02:40:00 PM »
I've totaly remake the Megapurge program.
It call TotalPurge and it is Totally Free.
Enjoy !
Downloads:
TotalPurge 32 bits
TotalPurge 64 bits
Keep smile...
trogg
« Reply #64 on: January 20, 2011, 03:44:09 PM »
Sweet!!!
Thanks for sharing
You have the coolest looking dialog boxes. very intuitive...
Brick_top
« Reply #65 on: January 21, 2011, 05:50:09 AM »
dhatch doesn't work in autocad 2004  :cry:
VVA
« Reply #66 on: January 21, 2011, 08:31:08 AM »
Enjoy !
Downloads:
TotalPurge 32 bits
TotalPurge 64 bits
Now I know 2 totalpurge :)
TotalPurge v. 4.0
Andrea
« Reply #67 on: January 21, 2011, 09:21:18 AM »
Enjoy !
Downloads:
TotalPurge 32 bits
TotalPurge 64 bits
TotalPurge v. 4.0
Well, I didn't know about that sorry.
Now you have a choice between my version who are compatible 2011 32 or 64 bits (multi-language)...
and the other release compatible only 32 bits and 2010. (russian and English only) :P
But to be serious,...It seem to be an interesting tool to try.
thanks VVA for the link.
Keep smile...
Andrea
« Reply #68 on: January 21, 2011, 09:28:31 AM »
Sorry Brick_top..
I didn't use 2004 for few year now.
I need to re-install 2004 to test and know what are the errors.
but time is missing a bit and we need to look foward.
thanks anyway for the info.
Andrea.
Keep smile...
Andrea
« Reply #69 on: January 21, 2011, 09:31:01 AM »
Sweet!!!
Thanks for sharing
Thank you Trogg. I hope you like it.  :roll:
Keep smile...
Brick_top
« Reply #70 on: January 21, 2011, 09:37:38 AM »
Sorry Brick_top..
Andrea.
fortunately in a couple of months my boss is going to buy a newer version of autocad.
I love this routine.. congratulations on you being awesome  8-)
Krushert
  • FREE BEER Tomorrow!!
« Reply #71 on: January 21, 2011, 10:57:00 AM »
Hi Andrea,
I noticed form your screen shot that deleting of RegApps was not an option.  Is that taken care of behind the scenes.
I am also getting a dialog error message of Missing Config file but I can see the TotalPurge.cfg file in the folder.  At the same time I am getting this error in the command line
Command:
TOTALPURGE *Cancel*
bad argument type: consp nil
ACA 2010 on Win7 64
Andrea
« Reply #72 on: January 21, 2011, 12:32:15 PM »
ok...
do you have any error when loading the program ?
Keep smile...
Krushert
« Reply #73 on: January 21, 2011, 12:37:00 PM »
ok...
No error when I installed or when Apploading?
Command: APPLOAD
TotalPurge.VLX successfully loaded.
Command:
TotalPurge 2.0 By DuctiSoft inc.
Command:
Andrea
« Reply #74 on: January 21, 2011, 12:39:57 PM »
ok..let me do some check...i'll be back in a few minutes
thanks.
Keep smile...
