Author Topic: Dhatch. New Way to Hatch !  (Read 44903 times)
Andrea
Re: Dhatch. New Way to Hatch !
« Reply #45 on: December 31, 2008, 12:25:48 AM »
Dhatch v.4.3
New additions....
this release show also the Angle and Scale Value Dynamicly !
you will notice the text color switching when activated and keep same textsize when zooming !
Keep smile...
« Reply #46 on: December 31, 2008, 12:31:49 AM »
Andrea,
Have you tested the performance of the text in a large drawing with many xrefs? I had originally put something similar to that into my version, but later noticed significant lag in big drawings.
Ron
Andrea
« Reply #47 on: December 31, 2008, 12:33:35 AM »
Andrea,
Ron
tested on 10.731 MB 3D drawing...and run fluently on my PC.
With and without Xrefs.
« Last Edit: December 31, 2008, 12:43:03 AM by Andrea »
Keep smile...
GDF
« Reply #48 on: December 31, 2008, 10:08:33 AM »
Andrea
Love you updated version.
Andrea
« Reply #49 on: December 31, 2008, 10:42:32 AM »
Andrea
thanks Gary..  :wink:
Keep smile...
« Reply #50 on: December 31, 2008, 11:06:31 AM »
Andrea,
Ron
Good to know...must be something with our in-house software (it's a bit on the bloated side) :x
Andrea
« Reply #51 on: January 02, 2009, 01:55:48 PM »
Andrea,
Ron
In our office...we use several client and add'on programs..
some of these put many scrap on  drawings..
All user run my MEGAPURGE program when saving.
allowing user to reduce filesize and remove all un-needed scrap.
it contain all AutoCAD purge and Audit function and extra cleaning
all The options are saved in our network drive in a specific user configuration.
that allow us to change PC without doing anything.
Since MEGAPURE is instored in all offices, user saw 90% more effiencienty, and some times reduce file over 70%.
some of our department work with DWG file over 90MB AFTER MEGAPURGE it.
Keep smile...
Andrea
« Reply #52 on: January 07, 2009, 02:37:24 PM »
New Feature..
Dhatch 4.4.1
Dhatch allow to get specific PAT file.
eg:
(dhatch "e:\\andrea\\mypersonalhatch.pat")
With this feature you can use your own personal Hatch pattern
or share over the network your PAT file.
:kewl:
Oops....Revised.
« Last Edit: January 07, 2009, 08:42:12 PM by Andrea »
Keep smile...
daveacad
« Reply #53 on: January 08, 2009, 12:33:15 PM »
Hi Andrea,
where to find Megapurge 2008?
in google no way to find it.
any more infos about it?
tnx,
d,
Andrea
« Reply #54 on: January 08, 2009, 02:44:32 PM »
Hi Dave.
MegaPurge was created for Our Office user..
I can't share-it unfortunatly.
But I think there are some program doing similar..
CFGpurge or SuperPurge....
Just take a look on this forum...i'm sure that someone can show you something.
they are many skilled programmer here.  :wink:
Bye the way....Welcome to theswamp.  :police:
Keep smile...
daveacad
« Reply #55 on: January 13, 2009, 07:32:50 AM »
Hi Dave.
Andrea,
thank you so much. even for the welcomes here.
d.
Andrea
« Reply #56 on: January 21, 2009, 05:19:10 PM »
Dhatch 4.5
I have made some tests and play with MTEXT.
so i've decided to add MTEXT as a Dynamic Menu and allow user to play with.
You will see on this animated GIF the MTEXT entity changing Dynamicly
(Font and Text color when activate or not.) and following the
Grdraw line color changing from Red to blue when the option is activated
I've forced the ARIAL font to have a good text looking.
To select press SPACEBAR
To Activate the option press Enter
you can Switch Pattern by pressing TAB or Shift+TAB (reverse)
you can move your mouse to update Dynamicly the Hatch or...
press "V" at anytime to enter any Value for Angle, scale, rotation, Origin (as list), and even Pattern Name.
Dhatch create a List of all available Hatch Pattern on Acadiso.pat or acad.pat depending the
Measurement variable. All custom Hatch Pattern Found will be added to this list.
Hatch will be Associated if entity is selected.
By playing with MTEXT....This give me an Idea (just for test)..
Create Dynamic Menu with DropDown who can read XML files..(eg  *.cui)
But time is missing a bit here....and i'm not that familar to XML.
so if someone is interested...I'm curious to see.
any comment will be appreciated.
« Last Edit: January 22, 2009, 05:05:47 PM by Andrea »
Keep smile...
Birdy
« Reply #57 on: January 21, 2009, 05:38:13 PM »
Truly awesome.
 :kewl:
Andrea
« Reply #58 on: January 22, 2009, 10:39:34 AM »
Keep smile...
GDF
« Reply #59 on: January 22, 2009, 02:29:33 PM »
How do I change the hatch pattern, this does not seem to work.
