Author Topic: Dhatch. New Way to Hatch !  (Read 44476 times)
Andrea
Re: Dhatch. New Way to Hatch !
« Reply #30 on: December 19, 2008, 11:30:09 AM »
New release....Dhatch 2.2
New Feature Allowing user to move the Origin Point.  ;-)
« Last Edit: December 19, 2008, 11:38:33 AM by Andrea »
Keep smile...
« Reply #31 on: December 19, 2008, 11:44:01 AM »
Nice  :-)
Andrea
« Reply #32 on: December 19, 2008, 11:52:43 AM »
Wow !!  this is weird..but very unexpected !!
I can even change the Hatch Patern Type IN REAL TIME !!
this give me more idea !!
an Hatch Pattern Real Time Editor !!    :ugly:
Keep smile...
Andrea
« Reply #33 on: December 23, 2008, 01:34:19 PM »
New Release..
Dhatch v.3
In this version:
-Solid Hatch accepted
-Work for Ellipse
-You can select object or click INSIDE a closed object
-New Options: (S)cale/(H)atch/(O)rigin/(C)olor
-You can change Origin in real time and continu the function.
-Osnap follow the SNAPANG variable.
-Diffrent ggrdraw vector color when using the Origin option.
-Color option show the 256 autoCAD color dialog Box during the hatch.
-Auto-Language version detection. (French / English)
That was my last post for this year.
I would like to send my greeting for all of you and your family
Merry Chrismas and Happy new year !
Keep smile...
M-dub
« Reply #34 on: December 23, 2008, 01:36:53 PM »
Thanks Andrea!  Again, Great routine!
Merry Christmas to you as well!  See you in 2009.  :)
« Reply #35 on: December 23, 2008, 01:52:04 PM »
For shame, encouraging hard coded colors!!
Otherwise very nice work.
Merry Christmas and Happy New Year to you and your family / colleagues Andrea.
« Reply #36 on: December 23, 2008, 02:07:58 PM »
Andrea,
This is what I see after trying to run version 3.0:
Select Entity to Hatch...
(S)cale/(H)atch pattern/(O)rigin/(C)olor:; error: too few arguments
Andrea
« Reply #37 on: December 23, 2008, 02:51:58 PM »
Oops..
fixed !
thanks all.  8-)
Keep smile...
Andrea
« Reply #38 on: December 26, 2008, 12:17:56 AM »
Final version ! ( I hope )  :?
Dhatch v. 4.0
New command: DHedit (editor)
Fix:
- Case sensitive
- Undo Redo
Sorry guys....can't resist until 2009.. ;-)
« Last Edit: December 26, 2008, 10:35:47 AM by Andrea »
Keep smile...
stevesfr
« Reply #39 on: December 26, 2008, 09:50:06 AM »
 :-(  oops, something is amiss with the new ver 4 ?   :|
no function definition for Editor ?
Can't remember what I'm supposed to forget.
GDF
« Reply #40 on: December 26, 2008, 10:18:07 AM »
you need to add the following to this line of code...
;;      -New function DHEDIT (editor)
Andrea
« Reply #41 on: December 26, 2008, 10:37:28 AM »
thanks GDF..  fixed. !  :-)
Keep smile...
bdeshawn
Re: H.O.S. New Way to Hatch !
« Reply #42 on: December 28, 2008, 01:23:31 AM »
Pretty nifty Andrea. Shame you're not updating the hatch's angle dynamically too. I know, version 1.01. :)
I have think of that also...but this was for my own utility..  ;-)
that's why you have the code..   :evil:
Andrea:  It is cool.  I was having some problems with seeing the scale work in an architectural drawing.  Also, when I had Selectionpreview turned on (mine was set at 3), it would hang continuously.  It might be something that you should probably toggle the system variable on.
Bill DeShawn
Andrea
« Reply #43 on: December 28, 2008, 10:52:21 AM »
Bill DeShawn
Hi Bill,...
I have no problem with this variable...could you make more test on it ?
and maybe show me some pic ?
by the way,...welcome to the swamp !   :-)
« Last Edit: December 29, 2008, 05:30:16 PM by Andrea »
Keep smile...
Andrea
« Reply #44 on: December 29, 2008, 05:29:42 PM »
New release..
Dhatch v.4.2
Allow user to put numeric Hatch Scale Value.
Keep smile...
