Author Topic: possible entmod-bug in 2007?  (Read 1866 times)
Cider
« on: December 16, 2008, 09:20:47 AM »
Hi, could anyone confirm this?
Open a new drawing, set CSHADOW to 1, insert a Block with attributes and try to set an Attribute-Value using entmod.
If I try this routine in ACAD 2007, the Attributedefinition gets a new groupcode (284, Value 1, which means it casts shadows) and i cannot entmod the attributes of the blocks inserted.
There appear to be no problems when using ACAD 2008.
regards
Martin
due to budget cuts, the lights at the end od the tunnel willbe turne d off.
Win10 , Bricscad 10-18
